February 04, 2026, 04:02:44 PM *
Author Topic: carbs float bowl removal  (Read 1968 times)
tonysnell
United Kingdom
« on: April 10, 2012, 12:12:16 PM »
Hi just removed carbs now need to take float  bowls off do i have to undo hex screw on water ways if so what is the best way as they will not come undone with hex key
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: April 10, 2012, 02:16:46 PM »
"do i have to undo hex screw on water ways if so what is the best way as they will not come undone with hex key"
What are "water ways"? And what "hex screws"?
I've removed my carbs to replace the clogged pilot jets, but I only needed to remove the float bowl screws that were phillips (richards). If you have allen screws on your float bowls,...well I'd have to say that someone had fooled with the carbs sometime ago.
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: April 11, 2012, 07:35:22 AM »
Picture?
Water ways, might that be the fuel feeders to the other carbs?
tonysnell
United Kingdom
« Reply #3 on: April 11, 2012, 10:31:18 AM »
sorry don't know how to add pictures but there is a water circuit around the carbs going bacak to the radiator
« Reply #4 on: April 11, 2012, 10:53:13 AM »
You stated that you removed the carburetors,, so,, I guess you need to describe the 'water ways' that return to the radiator.. I've not ever seen such a thing,, you may have one of them thar special Valkyrie's..  Normally once the carburetor assembly is removed you just flop it over and remove the float chamber screws.. The screws can be troublesome but the right driver head, sometimes a little heat or a hand impact driver will persuade them to release they're grip..
Momz
« Reply #5 on: April 11, 2012, 11:20:57 AM »
OK, the "water ways" are the external cooling passages on the top side of the engine cases.
Tonysnell, why would you need to get into the cooling passages if you have removed the carbs? The cooling tubes have no direct link to the the carbs.
Do you mean that the carbs are loose from the intakes and you need to remove them from the top of the engine? If that is the case, then remove the coil from the left side of the frame and the top left motor mount. the carbs will then be able to be removed.
I'd recommend that you download the Valkyrie Service Manual (PDF) from the Valkyrie Norway website before you attempt any further disassembly.
« Last Edit: April 12, 2012, 07:31:59 PM by Momz » Logged
« Reply #6 on: April 11, 2012, 11:38:35 AM »
+1  Cheesy
http://www.valkyrienorway.com/download.html
My rides:
« Reply #7 on: April 12, 2012, 05:23:21 PM »
Here is the pic Tony sent me.
I would have thought there was only vacumm and gas lines on the carbs.
« Last Edit: April 12, 2012, 05:25:58 PM by gordonv » Logged
Momz
« Reply #8 on: April 12, 2012, 07:31:16 PM »
I have three Valkyries and I can say that I've never seen anything like that.
I did notice that the pilot air screw is not like any I've ever seen either. All mine are "D" shaped.
I checked the Service Manual and there are no views like in the above post.
« Reply #9 on: April 12, 2012, 08:14:30 PM »
Tony, we are talking a Valkyrie, 6 carbs total?
Not some other bike, and not 2 carbs like on a GW?
« Reply #10 on: April 13, 2012, 05:36:18 AM »
Apparently he's not responding, but, it looks like he has one of them thar special Valkyries.. I've not seen any of the European models..
9Ball
« Reply #11 on: April 13, 2012, 06:13:21 AM »
It's hard to tell, but that almost looks like a carb bowl drain system....much different than any of the Valkyrie carbs I've worked on.  The drain screw assembly looks different too, along with the different pilot screw.
Could be European difference...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
tonysnell
United Kingdom
« Reply #12 on: April 13, 2012, 02:05:17 PM »
Hi yes this is a year  2000 valkyrie these tubes connect to the radiator i have been told on the valkyrie uk facebook that they are to stop carbs iceing up
« Reply #13 on: April 13, 2012, 02:10:53 PM »
Honda has had water jackets on some of their carb systems, my VTX 1300R is that way. But I have to agree that looks like no Valk carb I've seen. That pilot screw looks modified.
My rides:
« Reply #14 on: April 13, 2012, 05:27:48 PM »
So it's a UK version, that's why most/all of us haven't seen or heard of it.
I think I would start with removing the lines. That rusted hex screw, was that the one you are talking about? Do you have the service manual for the UK/Europian version?
I don't know what you would need, but if after loosening the screws for the bowls and it doesn't seem loose enought, then consider trying one.
