November 19, 2025, 04:13:11 AM
Service Pinion Cup
Topic: Service Pinion Cup (Read 2311 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
Service Pinion Cup
May 21, 2009, 03:31:22 AM »
Does "service the pinion cup" mean simply to pull the driveshaft and grease? Is there more to this?
MP
North Dakota
Re: Service Pinion Cup
May 21, 2009, 04:07:43 AM »
Yes, you need to clean out the "cup", and make sure the oil holes in it are clear. Then reassemble with a small amount of grease on the splines, not moly paste. Rear end lube actually comes in and out thru those holes, lubing the cup and splines. Not the grease.
"Ridin' with Cycho"
Tundra
2014 Valkyrie 1800
Seminole, Florida
May 21, 2009, 04:12:57 AM »
=> InZane XXV
