February 04, 2026, 03:56:17 PM *
Author Topic: Carb jet kits  (Read 2078 times)
mmurffy03
03 standard
toms river new jersey
« on: April 11, 2012, 02:06:21 AM »
anybody know who the best rejetting kit is made by?
« Reply #1 on: April 11, 2012, 05:02:33 AM »
unless u are modifying the air box and the exhaust, u don't need a jet kit. first try opening up your idle mixture screws. any pilot jet is good up to 4 turns out, if u need more than that, then next size PJ is required. With opening up the screws u can also shim the needles.
Factorypro kit is the most complete kit includes main jets. other kits are just needle kits and are the richest of all needles avail, no main jets.
« Reply #2 on: April 11, 2012, 11:06:27 AM »
Why do you want to re-jet ?? ???
« Reply #3 on: April 11, 2012, 11:48:55 AM »
+1 what Patrick asked.   ???
My rides:
mmurffy03
03 standard
« Reply #4 on: April 11, 2012, 04:37:08 PM »
had a idle i was unhappy with but was just doing some tinkering and sprayed some starter fluid to check for leaks and had a jump in RPMS at the intake runners of all the cyls so i ordered a set of runner gaskets from redeye tech and will try that next
« Reply #5 on: April 12, 2012, 12:52:23 PM »
When you have your intake tubes off, it would be a good time to pull your pilot screws and clean that passage and install new O-rings on the pilot screws. Redeye also has the pilot screw O-rings made of Viton. Turn you pilots out 2.25 turns. Once you have her buttoned up, top your hard work off with carburetor synchronization. I bet she'll just purrrrrr!   Grin
My rides:
mmurffy03
03 standard
« Reply #6 on: April 12, 2012, 01:10:01 PM »
i havent touched my pilot screws so far do they come out without without carb float bowl removal ?
« Reply #7 on: April 12, 2012, 01:18:27 PM »
Yes! In fact, You may have noticed that Rich at Redeye has a pilot screw tool for sale also that is quite handy.
My rides:
mmurffy03
03 standard
« Reply #8 on: April 12, 2012, 01:55:16 PM »
i am gettint the tool with my orings
« Reply #9 on: April 13, 2012, 04:07:20 PM »
Keep us posted!  Smiley
My rides:
BradValk48237
Oak Park, MI
« Reply #10 on: April 14, 2012, 07:16:24 AM »
I am also having a running rich issue, has been that way since i got it..... can you post the link to Redeye?
Anyone in the Detroit areas wanna give me a carb lesson? LOL
Brad
wild6
(Old enough to know better)
Vernon, NJ
« Reply #11 on: April 14, 2012, 07:20:42 AM »
Brad
http://redeye.ecrater.com/
BradValk48237
Oak Park, MI
« Reply #12 on: April 15, 2012, 09:08:22 AM »
Ordered the tool from Redeye..
Looked on here and couldn't find it, but is there a guide to setting the pilot jets...
Like which way to turn to set to zero and the which way to turn to correct-2-2.5 turns to set?
Any other hints or tricks?
Brad
« Reply #13 on: April 15, 2012, 06:19:52 PM »
You can download the service manual here and it covers it all.
http://www.valkyrienorway.com/download.html
My rides:
BradValk48237
Oak Park, MI
« Reply #14 on: April 15, 2012, 06:23:43 PM »
I have the Clymer... just didnt go out to the garage and read it......   Wink I will now.
Brad
« Reply #15 on: April 16, 2012, 08:34:28 AM »
You turn your pilots in clockwise to where they just lightly seat. Don't crank on them, you may damage them. Then turn them counter clockwise to the number of turns your looking for. It helps me to place the D tool on the pilot head then make a visual mark on it with a Sharpie so I can count the revolutions based on that mark's position.  Wink
My rides:
BradValk48237
Oak Park, MI
« Reply #16 on: April 16, 2012, 09:10:34 AM »
Thanks! That was what I was looking for.
