February 04, 2026, 03:56:42 PM *
Author Topic: What's leaking?  (Read 1567 times)
vw70blue
Tampa, FL
« on: April 13, 2012, 08:38:54 AM »
I have a 99 Tourer, 48,000mi. Recently I have noticed a brownish liguid leaking from my #1 intake where it attaches to the head. It is very little and only leaks out after riding a while. Sometimes it does not leak at all. It does not smell like gas nor is it slippery like oil.  Does anyone know what it could be? If the gasket needs to be replaced, is it a hard job?  Any suggestions will be greatly appreciated. Thanks
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: April 13, 2012, 08:41:16 AM »
Intake manafold gaskets (O rings)...  Easy fix!
Black Dog
Don't you know...
9Ball
« Reply #2 on: April 13, 2012, 08:42:27 AM »
replace the o-rings and your problem is solved.  Redeye.tech on ebay sells good quality items.  A socket and philips screwdriver are all that is needed...do one at a time.  Easy job...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
vw70blue
Tampa, FL
« Reply #3 on: April 13, 2012, 10:17:53 AM »
Thanks guys. What a relief to know it's someting simple. Grin
sugerbear
wentzville mo
« Reply #4 on: April 13, 2012, 11:23:19 AM »
NO NO NO. it's not something simple. the old girl is done for.
better send her to me for a proper burial.   Evil Evil Evil Evil
 2funny 2funny
« Reply #5 on: April 14, 2012, 07:51:17 AM »
Always start looking high for a leak.. Look for signs of a leak up the intake near the upper clamps and if there is none, then the leak is probably the intake/head o-ring.. Like was said, its easy, loosen the the upper clamps and remove the 2 intake retainers and pull the intake out.. You'll see the o-ring.. Some will argue this, but, the o-rings can be found at your friendly local o-ring store/hardware store.. Its either a #122 or #123 I can't remember which and I prefer the 'fatter' one anyway.. I haven't had a problem with these $.25 rings and they're still in after about a dozen or more years so they must be made out of the good stuff..
