November 24, 2025, 05:47:03 AM *
Author Topic: Blinkers on the blink  (Read 1692 times)
Mofla
San Antonio TX
« on: April 14, 2012, 03:00:00 PM »
Blinkers stopped working. Haven't torn into it yet but back in the cool weather I greased them up because if slow response. Worked fine till recently, now no response !
Input please !!!
Mofla SATX
« Reply #1 on: April 14, 2012, 04:55:44 PM »
If the lights light, then it sounds like a flasher problem.. If the lights don't light then you probably have a ground or connection problem.. Maybe too much grease??
« Reply #2 on: April 14, 2012, 05:02:17 PM »
Clean out all the grease and relube with a dielectric grease. Ace Hardware sells SuperLube in their automotive section. The factory grease gets hard after several years and the contacts become dirty. Good luck.
Mofla
San Antonio TX
« Reply #3 on: April 15, 2012, 01:40:29 PM »
Knew I could count on yuzz !!!! I'll try it out ! TYVM !
Mofla
San Antonio TX
« Reply #4 on: April 15, 2012, 06:18:20 PM »
Cleaned out old grease and the lights light soooo I'm thinkin flasher ?
Where is it located an where can I get a replacement ?
Thnks again !
« Reply #5 on: April 15, 2012, 07:43:54 PM »
Page 19-21 of the manual. Where all the rest of them are, around the battery, behind the water bottle on the, I think, LH side cover. Looks like the 2nd or maybe 3rd in on the front of the battery box.
Mofla
San Antonio TX
« Reply #6 on: April 16, 2012, 06:59:47 AM »
Thnks ! Duh !
Mr.BubblesVRCCDS0008
« Reply #7 on: April 16, 2012, 07:16:31 AM »
You can replace with an electronic flasher from auto store. Works as a timer and doesn't care about load, works with any number all type of bulbs.
Mofla
San Antonio TX
« Reply #8 on: April 16, 2012, 02:52:03 PM »
Mr Bubbles, I checked out the flasher units @ the auto parts but I would not know where to start trying to "adapt" them to existing plug. I found a rePlacment on line for 42. bucks plus shipping.
Didn't order yet,,,,,
« Reply #9 on: April 16, 2012, 02:56:30 PM »
$42 for a flasher !!??  Now thats capitalism at its best !! Or maybe worst..
« Reply #10 on: April 19, 2012, 07:42:06 AM »
Did mine a long time ago. It seems it was just a 2 pin flasher that cost about 13 dollars. I could be wrong my remembery isn't what it use to be.
Mofla
San Antonio TX
« Reply #11 on: April 26, 2012, 06:09:19 PM »
aint fixed yet !!! Got a new ( used ) flasher from Gordon and after some searching found the right relay. Replaced with new and same result. Cleaned switch and regreased with dielctric grease. Nothing. WIth ignition turned on headlamp, and both blinkers light up. When you switch to blink the desired lamp goes out the other stays on but no blink. Why dont the rear bulbs ( indicators) light up as the front do. I noticed the rear have single elements and the fronts dual. Help !!! tickedoff
John U.
Southern Delaware
« Reply #12 on: April 26, 2012, 07:34:34 PM »
The front signals have running lights on the second elements. The running lights go out when the directional signal is activated. No runnng lights on the rear signals. Have you checked the elements?
Mofla
San Antonio TX
« Reply #13 on: April 27, 2012, 08:08:34 PM »
After rePlacing the flasher replay with no change I went to blinker switch for the third time and after a very thorough inspection found that the top copper switch selector bar had somehow melted itself into the plastic housing and was not floating like it should have been resulting in a bad, or no connection. A little trim and sanding to contact and it is once again working !looking back I should have know it was the switch because it was there that troubles began. O well hope this helps someone else ! Thnks for your replies !
« Reply #14 on: April 28, 2012, 08:32:42 AM »
The turn signal switch along with the starter button are designed for the electrical loads found on a stock bike.
When modifications are made (such as adding loads) without proper preparations, well, that is when bad things start to happen.
Like melting parts within the switches.
Not saying this is the case.
Just want to state the truism.
Mofla
San Antonio TX
« Reply #15 on: April 28, 2012, 04:37:27 PM »
Thnks for the input Ricky D ! Was wonderin why it did that it the first place.
Makes sense, I don't have any add on in my 6.5 k ownership but can't speak for the first 50k
Tommy B
