February 04, 2026, 07:15:50 PM *
Author Topic: Intake o-ring install  (Read 1306 times)
vw70blue
Tampa, FL
« on: April 18, 2012, 06:25:15 AM »
Just got my o-rings from Redeye. Thanks to jrhorton for the tip. I was thinking about replacing the one that was leaking. Since it was so easy to replace, I decided to replace the others. Good thing I did. All o-rings were leaking. I notice that brown stuff on the outside of the o-rings and all were soaked w/ gas. I appreciate everybodys input. This forum is the best. Thanks again. Roll Eyes
9Ball
« Reply #1 on: April 18, 2012, 06:53:37 AM »
now you're a Valk mechanic....your next project should be to inspect all the vacuum tubing (PAIR valve and petcock) and intake vacuum plugs and replace them as they are probably old and will eventually cause you problems.  Redeye.tech sells these too.
Good luck....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
vw70blue
Tampa, FL
« Reply #2 on: April 18, 2012, 05:17:40 PM »
It's all done. Thanks
