February 04, 2026, 07:15:52 PM
Adjusting Progressive 440 schocks
Topic: Adjusting Progressive 440 schocks (Read 1157 times)
Bonzo
April 18, 2012, 02:32:00 PM »
Is there a way to check if both side are even?
Woops, I'm sorry.
Valker
Wahoo!!!!
Texas Panhandle
Re: Adjusting Progressive 440 schocks
April 18, 2012, 03:27:21 PM »
There are 'lines' on the shock body itself. These should be in the same spot on both sides. I think there are either 3 or 5 lines on each. If you can't see the lines, they are not turned down at all yet.
Bonzo
April 18, 2012, 03:41:16 PM »
Thanks, I will check now!
Woops, I'm sorry.
Valker
Wahoo!!!!
Texas Panhandle
April 18, 2012, 05:12:38 PM »
Sorry, I forgot to say that they are on the top part above the chrome adjuster and below the top mount bolt.
