March 31, 2026, 12:37:26 AM *
Author Topic: Do they no longer make this?  (Read 2785 times)
F6BANGER
Albuquerque NM
« on: April 20, 2012, 03:15:05 PM »
 CHROME VALKYRIE ALTERNATOR COVER
21333-MZ0-A00
New from hdl....$35.98
#6   http://www.hdlparts.com/fiche_section_detail.asp?section=148849&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3478
Used on ebay....$61.00
http://www.ebay.com/itm/1999-Honda-GL1500CF-Valkyrie-Interstate-Alternator-Chrome-Cover-No-Bubbles-/140738754085?hash=item20c4aef625&item=140738754085&pt=Motorcycles_Parts_Accessories&vxp=mtr
Either they are not being made anymore or people just dont do their homework.... uglystupid2
PAVALKER
Pittsburgh, Pa
« Reply #1 on: April 20, 2012, 03:53:52 PM »
They are still available.... I had a new one in standby and the one my Valk was wearing gave up when there was gas spilled on it.  So, I installed the new one in standby from 3 years ago, and ordered/received a new one which I placed in standby.   I may try to remove the old plastic chrome from the one bubbled up..... then again, I might just let it sit on the shelf next to the new one I have in standby.
I had my local dealer price match HDL/DLP as well.... as they always do.  I had to pay tax, but didn't have to pay shipping or handling.
« Last Edit: April 20, 2012, 03:58:00 PM by PAVALKER » Logged
John
bg
Cumming, Ga
« Reply #2 on: April 20, 2012, 03:54:06 PM »
don't know but mine is peeling.
« Reply #3 on: April 20, 2012, 03:56:51 PM »
Sure do, just ordered one about a month ago from Service Honda. Cost $35.72, was shipped in less than a week along with other stuff.
Red Diamond
Beaumont, Texas
« Reply #4 on: April 20, 2012, 03:57:15 PM »
HDL has them in stock, got one a month ago, cheaper than a used one.
Karen
Boston MA
« Reply #5 on: April 20, 2012, 05:20:45 PM »
I replaced mine, may have damaged the original with chrome polish thinking it was metal instead of plastic.
B
Capital Area - Michigan
« Reply #6 on: April 20, 2012, 06:55:21 PM »
Just got a new OEM one. I lined it with an insulation blanket; hopefully the chrome won't wrinkle.
Challenger
« Reply #7 on: April 20, 2012, 07:01:05 PM »
I got one in January from this site http://www.dealercostparts.com/  It was $32.00
KSDragonRider
Salina, KS
« Reply #8 on: April 21, 2012, 12:11:12 PM »
I just ordered one today from HDLparts.com  30 some bucks and should have it in a few days.  Thank you for posting this thread so i could remember to order it with a new air filter.
Dalen & Shay -> Salina, KS
VRCC Member #33950
DFragn
« Reply #9 on: April 21, 2012, 12:34:52 PM »
     Although it's not impossible that the alt. cover plating separation is due to chemicals. I believe it is primarily heat related - generally from long idle times. Even if chemicals come into play it is the heat that sets it to first crinkle at the logo box-out corner(s) where the vacuum plating is much thinner. It is heat, see pic, that warps the ABS.
     I had some left over paint from my fairing & pod project so I opted to peel/prep/paint/clear my alt. cover.
     Several months later, after a carb clean/rebuild that I spent a very long time syncing with a 6' man-o-meter. The man-o-meter is so acutely accurate and sensitive with adjustments it shows other carbs previously balanced way off with another carb adj..
Close to an hour of dinking with it I accepted well enough & let it be.
But the heat build up warped my painted cover terribly, the paint fared well though. I need to buy a new one now.
F6BANGER
Albuquerque NM
« Reply #10 on: April 21, 2012, 01:16:16 PM »
I really like what you did with it. How long did it take to peel the chrome off? Once started, does it come off easily? thanks
DFragn
« Reply #11 on: April 21, 2012, 04:30:09 PM »
Peeling the face was just a few minutes. The back took a little longer.
I then filled & sanded the left front side to re-contour the surface from heat warp.
Primer, color & clear. Wet sand clear and polish.
All'n all about 3.5 hrs. total.
I used http://colorrite.com/ rattle-can products.
I've had some practice tho'...fairing & pods.
F6BANGER
Albuquerque NM
« Reply #12 on: April 21, 2012, 05:00:14 PM »
