March 31, 2026, 12:37:34 AM *
Author Topic: Who makes this and what is it called?  (Read 1167 times)
F6BANGER
Albuquerque NM
« on: April 21, 2012, 11:52:08 AM »
Its in the trunk of my Interstate and its not letting the right brake light work. It doesnt have a brand name on it. Some type of tail light module. By the arrows, it looks like it was made 12/97
I will post in tech also. I really wanna find out what it is.
EDIT: Sorry, I shoulda put what it does.  Its hooked up to the blinkers to make the Trunk lights work as blinkers also.
« Last Edit: April 21, 2012, 12:18:21 PM by F6BANGER » Logged
tank_post142
south florida
« Reply #1 on: April 21, 2012, 11:53:25 AM »
why would you post it more than once?
I got a rock Sad
VRCCDS0246
« Reply #2 on: April 21, 2012, 11:56:28 AM »
Mainly because a good percentage of readers visit only one board most of the time.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: April 21, 2012, 12:07:47 PM »
Looks like where they tapped into the wiring for your trailer lights plug.  I see a hitch on your bike.  Cool
States I Have Ridden In
moreira72
VRCC# 33494
Clark, NJ. 07066
« Reply #4 on: April 21, 2012, 12:09:39 PM »
It looks like the black plug is from wiring for a trailer hitch.
Could be some kind of module for the brake/turn signals when you're pulling a trailer
F6BANGER
Albuquerque NM
« Reply #5 on: April 21, 2012, 12:14:06 PM »
Some people dont go to the tech boards and some tech board people dont come in the sandbox.
gregc
Media Pa.
« Reply #6 on: April 21, 2012, 02:28:45 PM »
  Looks like a trailer wiring break out box.  It lets the trailer lights be both turn signal and brake light on the same bulb.  Since the supply vehicle has different bulbs for brake and turn signal, it stops what would be back feed to the supply vehicle.   Without it if you stepped on the brake it would light up all the turn signal lights, and when you used the turnsignals it would flash the brake lights.
MNBill
Southern Minnesota
« Reply #7 on: April 21, 2012, 05:01:43 PM »
I had one wired into my bike for the trailer lights. Got mine at the local car supply store and wired it in. I had one go bad too. I am guessing the trailer plug is so you can take the trunk off ? The poster above was right, it converts the seperate blinkers/brake lights so they work one one bulb, on the bike they are seperate and on the trunk it is one bulb.
MNBill
SE Minnesota
F6BANGER
Albuquerque NM
« Reply #8 on: April 21, 2012, 05:17:40 PM »
Thanks all, Chrise2469 figured out what it was on the TECH BOARD. Does anyone know who makes it?
chrise2469
Winnipeg Manitoba Canada
View Profile Personal Message (Offline)
Re: Who makes this and what is it called?
« Reply #3 on: Today at 12:36:17 PM »
   Reply with quoteQuote
I'm just guessing without knowing which end goes to the trunk lights. if the lights go from the black trailer style plug to the interstate lights  it is a 5-4 convertor.
The other way around and it would be a vehicle to vehicle tail light convertor.  It takes your converted 4 wire signal-the trailer plug- and converts it back to a 5 wire signal.   Here's a different one:
http://www.etrailer.com/p-118158.html
You have to follow the wires to know what style of convertor you will need to replace the defective one.
Not much help but it's all I got.
EDIT:  The more I look at the picture it looks like a 5 to 4 convertor.  The 4 wire connector with the extended hood is a bit unusual and is confusing me a bit.
It could be early  hopkins 48915
http://www.etrailer.com/Wiring/Hopkins/HM48915.html
or a calterm 5-4
http://www.ebay.com/itm/Trailer-Light-Isolated-Power-Supply-Converter-5-4-wire-PM32-/290660635436
Master Blaster
Deridder, Louisiana
« Reply #9 on: April 21, 2012, 07:04:35 PM »
Most auto supply carries them.  There are two types, a powered and unpowered.  The powered type is the best and will insure the lights are bright.  Sometimes the unpowered ones will sometimes have a voltage drop and the lights will be dim.  Look for trailer light converter in the trailer wireing section.
