alph
« on: April 23, 2012, 11:31:06 AM » |
alright, i put in one of those Autovox cruise controls last year, and i love it. the only problem is, now, it only works in the afternoon when the temps are above 40*. anyone else ever have this problem? it stinks not having cruise when i'm riding to or from work.
anyone have any idea's?
BTW, vacuum is being pulled off of carberators 1 & 2, no vacuum canister (vacuum has never been an issue with just those two carbs), sometimes it works fine, then drops off. other times it won't even engage, but everything turns on. this ONLY happens on cool crisp mornings when the temp is BELOW 40, once it gets warmer it works fine.
Promote world peace, ban all religion. Ride Safe, Ride Often!!
Mr.BubblesVRCCDS0008
« Reply #1 on: April 23, 2012, 11:51:16 AM » |
I've installed 4 of thes unit over the years with only a broken wire and a burned out brake bulb that caused any problems. I'ld check the control panel for moisture, you can pop the cover off and clean the contacts. I've used mine down to 23 degrees with no problems.
alph
« Reply #2 on: April 23, 2012, 12:17:19 PM » |
i siliconed the heck out of that thing!! i'll give it a try though, it's a lot easier then pulling the fairing!!
i'll let you know what i find.
al.
alph
« Reply #3 on: April 23, 2012, 12:38:58 PM » |
nope, that wasn't it. pulled the cover, contact pads looked as good as they did last year, plus i had to peal off the silicone from all around it!! stuck good too. guess i'll be pulling my fairing....
NITRO
« Reply #4 on: April 23, 2012, 02:39:00 PM » |
I'm still voting for a bad connection someplace. Maybe the temperature thing is just a fluke.
When in doubt, ride.
alph
« Reply #5 on: April 23, 2012, 06:49:38 PM » |
well, for those that need to know, i found a kinked vacuum line. AGAIN!! same spot, this time i shortened my 90 degree adapter, there's no way for it to bend now!! hopefully i'll never have to take that fairiing off again!! (i've gotten good at it actually)
MP
North Dakota
« Reply #6 on: April 24, 2012, 04:01:42 AM » |
Mine quit working too. Lights come on on the control. Maybe a kinked vac line is my problem? Could you make a quick run over here and check mine out alph?  MP
 "Ridin' with Cycho"
