February 04, 2026, 08:51:41 PM *
Author Topic: side covers again  (Read 1773 times)
v-man1
« on: April 25, 2012, 04:25:29 PM »
Yesterday I asked for and received some very helpful info on removing the center cover between the side covers from some of you guys. All is done but removing the seat lock switch that is through the cover.I removed the clip,but how do I completely remove it out of the cover?Need to take It to be painted.I have owned my Valk for 5 years now and have received so much useful,helpful info here  .Thanks
« Reply #1 on: April 25, 2012, 05:17:22 PM »
If you've got the retainer clip on the back side off already, the switch assemble should be all free and wobbling around in there.  Best I remember, it's keyed to the mount that's on the back side.  Just turn it either quarter or a half turn and it should come out.
v-man1
« Reply #2 on: April 25, 2012, 05:24:09 PM »
got latch loose,but need cable released from lock to fully remove from cover
« Reply #3 on: April 25, 2012, 05:25:16 PM »
Do you not have the manual?
http://valkyrienorway.com/download.html
pg 2-3 (page 44) shows how to remove the covers.
I couldn't find anything on how to remove it from the cover, but I know it's simple I did it when I sold the cover from my wrecker IS. I think it was a slide clip.
Use the fiche,
http://www.bikebandit.com/houseofmotorcycles/1999-honda-valkyrie-interstate-gl1500cf-seat/o/m151389sch308139
It is a slide that holds the lock in.
« Last Edit: April 25, 2012, 05:27:41 PM by gordonv » Logged
v-man1
« Reply #4 on: April 26, 2012, 02:06:02 PM »
cant get cable separated from lock to remove it from cover
« Reply #5 on: April 26, 2012, 06:46:31 PM »
You turn/rotate it, and it will come out. I remember it being like a lot of other cables, throttles and the like.
« Reply #6 on: April 27, 2012, 08:16:40 AM »
I had to unbolt the latch at the top where the seat hooks in. This was one time where big hands were not an asset however. Getting that cable back in place on either end will test your patience.
v-man1
« Reply #7 on: April 27, 2012, 03:26:12 PM »
Thanks.The removing of seat latch and the rotate/lift of the cable ends got it out.
b1rks
« Reply #8 on: April 27, 2012, 07:09:29 PM »
I've taken the centre cover off twice in the last year , to repair a brken tab. And install light bar switch. Hated every bit of it. I removed last ,and installed first. The clip no problem. The cable a huge pain. I think I put cable on first.
