February 05, 2026, 12:54:14 AM *
Author Topic: Pod Light Install  (Read 2155 times)
X Ring
VRCC #27389, VRCCDS #204
« on: April 29, 2012, 05:39:44 AM »
There has GOT to be a trick to installing the rubber boots.  If you know it please let me know.
Marty
« Reply #1 on: April 29, 2012, 06:42:36 AM »
Bake them in the oven at 250 until softer (just guessing).  angel
X Ring
« Reply #2 on: April 29, 2012, 07:03:33 AM »
You were just complaining yesterday about people posting in a thread just to post and here you do the same thing.
Marty
« Reply #3 on: April 29, 2012, 04:29:50 PM »
Well sorry.  It was in humor as to the oven..... but I did think the general idea of warming them up might help them go on easier.
designer
Columbus, Ohio
« Reply #4 on: April 29, 2012, 05:34:36 PM »
If you cut the hole the right size, just fold them into the hole. They are rubber. You won't break them.
2002 Valkyrie Std
K&N Filter, Audiovox Cruise, I/S bags and trunk, Cee Bailey shield +2, ECT mod, radiator pods, driving lights, rattlebars kick shifter ,I/S ICM
NJF6Cowboy
« Reply #5 on: April 29, 2012, 06:27:57 PM »
Years ago I hit a deer and destroyed pod & light. Never liked the fog lights. My son purchased PIIA driving lights for the pods for me. Much better road lighting but a bit larger than the Honda fog lights.
Struggled for awhile, then I cut the rubber at the center of the outer edge. I then start at the bottom with the notch and work my way around. The cut seams together perfectly.
Hope this suggestion works for you.
X Ring
« Reply #6 on: April 29, 2012, 08:58:06 PM »
Thanks NJF6
Marty
X Ring
« Reply #7 on: April 29, 2012, 09:45:50 PM »
NJF6, can't say a similar idea to yours hasn't been playing in my mind today. Buy a 4-5 inch pair of driving lights and adjust the opening in the pods to fit then cover the edges with either chrome or black door edge guard trim.
Marty
Disco
Republic of Texas
« Reply #8 on: April 30, 2012, 03:14:59 AM »
When I recently installed a set of Big Mike's pod lights I found that even a millimeter of extra material inside the scribed lines would make it difficult to install the rubber.  If the pod plastic is removed all the way to the lines, the rubber will go on very easily.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
RainMaker
Arlington, TX
« Reply #9 on: April 30, 2012, 10:33:18 AM »
When I installed mine, I used a file to finish the edges to exactly where the guides were for the cuts.  That must be the key because the rubber boots just fold in and over after that.  There wasn't any trick to it other than getting over the fear of doing a total SNAFU on a hard to find part.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Phil57
Jenison MI
« Reply #10 on: May 19, 2012, 12:25:48 PM »
Where can I buy just the rubber  for the fog light. Mine is missing.
valkyriemc
NE Florida
« Reply #11 on: May 19, 2012, 02:25:48 PM »
Might try Pinwall on ebay. I got a choke cable from them when mine gave out. Saved some bucks and it was in real good shape. They pull bikes apart and piece them out.
Veteran USN '70-'76
X Ring
« Reply #12 on: May 19, 2012, 04:33:11 PM »
Contact Big Mike Terry @ Valkyrie Bling & More.  http://valkyrieblingandmore.com/
Marty
Phil57
Jenison MI
« Reply #13 on: May 19, 2012, 05:00:47 PM »
E mail sent thanks for the help.
X Ring
« Reply #14 on: May 19, 2012, 05:05:40 PM »
You're welcome.
Marty
