February 04, 2026, 10:40:16 PM *
Author Topic: digital gauges  (Read 1917 times)
jimmytee
Elizabethtown,KY
« on: April 29, 2012, 07:41:53 AM »
Hello
I've ordered a fairing from woody(Glenn). The gauge cluster has to be relocated to the handlebar and because of this, I'm considering going to a digital dash. Is there anyone here that has done this? If so what brands.I've seen many options and would be interested in any feedback. Thanks Jim
olddog1946
Moses Lake, Wa
« Reply #1 on: May 02, 2012, 10:24:42 AM »
I have Dakota Digital in one of my Chevelles, and I really like em. I believe they are currently making them for bikes as well.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #2 on: May 03, 2012, 05:43:46 PM »
Been done already look at the old tech archives.
jimmytee
Elizabethtown,KY
« Reply #3 on: May 03, 2012, 05:46:15 PM »
I did do a couple of searches but did not come up with anything
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #4 on: May 03, 2012, 06:08:37 PM »
I have a dakota display on one of my supercharged Valks. Works very well.
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
jimmytee
Elizabethtown,KY
« Reply #5 on: May 03, 2012, 07:14:26 PM »
Thanks Mike. Which model of gauges.I was looking at the 7000 series.I've ordered a fairing from Woody and I have to relocate the stock guages to the handlebar .I was thinking that the digital set would have a smaller footprint so to speak and look pretty sweet.How did you hook up the speedometer?The 7000 series comes with a sensor plus you can get an adaptor for cable drive situations.I don't know if the adaptor is compatible with the valkyrie's or not.I also thought of using the sender from an IS.Any thoughts are appreciated.How many blown valks do you own? I love the idea of doing that.Are kits even still available I wonder.
Jim
« Reply #6 on: May 04, 2012, 12:57:48 PM »
Puror/shock bushing gary had it on his bike and loved it
Big Mike
Taylor MI
« Reply #7 on: May 04, 2012, 03:41:24 PM »
The dakota works perfectly. A bit af a hassle to hook up but well worth it. The speedo adapter was a non issue also. I do have a 7000 series. I own 2 blown valks but have a deal on one of them so shortly it will only be one. I have a neighbor who owns a blown Valk also, his is an I/S! CAll Bill and see if he will put one together for you. It is however not cheap or easy. You will need to know what you are doing or have someone available that does. It is incredible to ride though. I almost do not want to ride the I/S anymore.
Big Mike
VRCC 23871
VRCCDS 0200
« Reply #8 on: May 04, 2012, 05:44:18 PM »
It's like a speedo correcter
Posted By: Þrúðr
Date: 8/6/2007 at 19:10:10
In Response To: Yup - thats what I want to do... (Brummer)
The DD unit accepts a MHz input, and outputs a MHZ output in relation to, but not the same as, the input.
I have a DD HLY-5000. It's been years ago I programmed mine. I didn't even see the PPM, I just adjusted while underway until it matched my GPSr. It's been dead nuts perfect ever since.
I'll try to find the op instructions on the HLY-5000 and see if I can retreive the PPM. I use the I/S sender directly to it.
http://vrcc.photostash.com/vrcc_12341/gauges.jpg
« Last Edit: May 04, 2012, 05:48:36 PM by Robert » Logged
jimmytee
Elizabethtown,KY
« Reply #9 on: May 04, 2012, 07:54:50 PM »
Robert,
You mentioned using the Interstate sender,that was one option I was considering.I've seen them listed on ebay for ten to thirty dollars and was wondering if compatible.As I understand it,the 7000 series has the ability for calibrating actual speed built in so a healer isn't needed.Dakota sells an adapter for the cable drive too.Not sure if it will fit the cable of the Valkerie or not.
I appreciate you guys commenting. This is my second Valkyrie.A 2000 standard.Had a 98 a few years ago and then I was bikeless for a few.When I was shopping again for a bike,valkyries were at my top of the list.I have always loved them since they first came out.It's partially bittersweet because of the fact thy're no longer in production.
So that brings me to big mike. I'm familiar with the magna charger as used in many super charged build like Lamonster's from several years ago.Is that the kit you're talking about?I am interested maybe for a project next winter.You say you have a deal one one of yours,you selling?I'm pretty comfortable turning wrenches.I'm a HVAC Refrigeration technician. I work with electronics, wiring and mechanical devices everyday of varying complexity.
Jim
« Reply #10 on: May 05, 2012, 05:51:51 AM »
I posted early posts by some that have already done what you want to do its in the archives. If you search using the heading that is in my post you will find the answer because Gary/puror does give a wiring diagram and the other post is more info on how to use the interstate sender. One adopted a VTX1800 speedo to a interstate and they did use the sender. Search using Dakota digital and you will see all the options.
« Last Edit: May 05, 2012, 05:59:29 AM by Robert » Logged
