November 24, 2025, 05:48:08 AM *
Author Topic: Vacume hose replace and air box removal HELP  (Read 1622 times)
Hotrodwing
Clarks Summit PA
« on: April 30, 2012, 03:42:42 AM »
I noticed that my vacline ont the rightside center carb is collasped and the left center carb line is crack.  It looks like I need to remove the air box.  How do I disconect the intakes at the air box?   Is there anything else i should look for?   What size vac line should I get? Any tips to make it goes easier would be much appreciated. Sad
Bone
« Reply #1 on: April 30, 2012, 04:00:21 AM »
Click on this link it will take you to an article in Shoptalk. Should answer your questions.
http://www.valkyrieriders.com/shoptalk/AirBox%20VentHose/AirBox.htm
« Reply #2 on: April 30, 2012, 05:10:05 AM »
you do not need to remove the airbox.  Its just two lille hoses
Hotrodwing
Clarks Summit PA
« Reply #3 on: April 30, 2012, 07:46:39 AM »
Chris you are right they are 2 little hose but they each connect at the same T fitting and it did not look like I could reach in there and remove or reconnect easily.  Believe me if I dont need to touch the air box that will be ok.  Also i noticed that the rightside hose is missing the little clamp at the intake. You know the ones that look like they don't do much anyway. Do I need to get one or will a friction fit be ok?
sugerbear
wentzville mo
« Reply #4 on: April 30, 2012, 09:03:38 AM »
if you don't already have them,might i suggest:
http://www.harborfreight.com/2-piece-11-inch-20-offset-45-angle-long-reach-needle-plier-set-33202.html
 Smiley
Hotrodwing
Clarks Summit PA
« Reply #5 on: April 30, 2012, 11:36:53 AM »
Thanks Sugar Bear, I was thinking of stopping at Harbor freight tonight after work.  Those sure look like they will work. cooldude
« Reply #6 on: April 30, 2012, 11:39:28 AM »
look in shop talk, it will describe the string method.  If you go buy 5/32 ID fuel line it will fit tight enough so you wont need clamps.
Works best if you remove the fuel selector knob (secret screw) so you can unbolt both ends of the tank and rock it to the right so the tops of the left carb bank is exposed.  Tie a long piece of strong string to the end of each of those vacuum tubes after you pop them off their intakes.  Then reach in over the carb bank with a hook make from a coat hanger and grab that T fitting and pull it out over the carbs.  once you have the T fitting out you can replace the hoses.  Leave the strings setting in the trac where the vacuum lines will go, retie the ends to the new lines and pull them back in place.
« Reply #7 on: April 30, 2012, 01:21:59 PM »
You can, but should not remove the rubber air tubes, the ones that connect the air box to the carburetors.
Loosen the clamps that fix the rubber air tube tightly to the carburetors.
Pull the air box out completely with the tubes all connected. It's very easy to do.
About reinstalling the air box, well, I know there are many who have trouble with this but I don't see the problem.
The air box is very easy to reinstall properly.
Akin to an old wives tale!
sugerbear
wentzville mo
« Reply #8 on: April 30, 2012, 02:01:50 PM »
always in my saddlebag.
if it were mine. i would take the airbox off, fix ALL the vac lines.
if you have one cracked, i'll bet there are others.
box isn't that hard to put back on. just put in one side, then the other.
also, buy the "heavy" walled vac line. it'll last a lot longer.
« Last Edit: April 30, 2012, 02:06:40 PM by sugerbear » Logged
Hotrodwing
Clarks Summit PA
« Reply #9 on: April 30, 2012, 06:09:03 PM »
Thanks everyone just finished up doing it the way Chris suggested, with the strings and coat hanger.It worked great and she is back to her old self. It took a little longer because  I had a full tank and when I went to siphon it out I got a mouth full of gas and even swallowed some.  Man the taste of gas sucks big time.  Wife got all nervous and called poision control.  They said I should be fine as long as I did not get any in my lungs.  I keep burping up gas.  I wanted to breathe on a match  to see if it would flame up, but the wife keeps freaking out.  Anyways thanks for the quick input.  Mike cooldude
« Reply #10 on: April 30, 2012, 06:16:19 PM »
Glad it worked.......but I didnt say anything about drinking gas in my instructions.........been there done that though.......your food will not taste right for 3 days
sugerbear
wentzville mo
« Reply #11 on: April 30, 2012, 10:30:15 PM »
and careful with those farts. 2funny 2funny 2funny
Chiefy
Sarasota, Florida
« Reply #12 on: May 01, 2012, 03:54:42 AM »
Never-never-never syphon gas by mouth.  A couple of drops (or so I'm told, and won't test it) in your lungs will kill you dead.
