February 04, 2026, 10:41:39 PM *
Author Topic: Thank God I caught it in time.  (Read 2603 times)
« on: April 30, 2012, 09:07:27 PM »
I noticed Chenaynay was shaking her ass when I'd jump on her hard, and my p205/60r16 yokahama was rubbing on the swingarm.  So yesterday before our Rogue Ride/shopping trip, I jacked her up and gave the rear wheel a shake.  Sure enough there was some play in the bearings so tonight I pulled the rear and am doing the double bearing mod.  How many have done this without using the nilos ring?
Here some pics, splines show some wear but are still serviceable
Sidewall rubbing on swingarm.  The major gouges were in this tire when it was given to me, the givee didn't do the nut cage mode and didn't like the darkside, I wonder why?
How many of you are cheap bastards like me and will put this tire back on?
Gary's (RIP) bushings with 11,000 miles on them, didn't pull the plate, they have some movement to them, but aren't destroyed like those in the earlier post.
« Last Edit: April 30, 2012, 09:11:01 PM by Skinhead » Logged
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #1 on: April 30, 2012, 09:18:46 PM »
I did the rear bearing mod but now i'm curious ..what is the  nilos ring?
If guns kill people where are mine hiding the bodies
« Reply #2 on: April 30, 2012, 09:30:41 PM »
It is a thin metal cover (like a washer) that you install to help keep dirt & water from getting in the bearing since you eliminate the seal used with the single row bearing.
Type Nilos rings in google, you'll see.
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 01, 2012, 02:13:38 AM »
10,000 miles after doing the article I pulled the wheel for driveline maintenance. There was no wear on the outside of the bearing.
Marty
vanagon40
Greenwood, IN
« Reply #4 on: May 01, 2012, 07:40:45 AM »
At least one in central Indiana.
olddog1946
Moses Lake, Wa
« Reply #5 on: May 01, 2012, 07:50:57 AM »
Those splines look exactly like mine did when I had that bearing go belly up. What really surprised me was how quickly that wear showed up. I'd had the rear apart for drive line maintenance about 2000 miles earlier and every thing looked like new.
And yes, I'd probably put that tire back on or maybe not, lol.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #6 on: May 01, 2012, 08:30:48 AM »
  Cheap old ba$tard here in the Ozarks. cooldude RIDE SAFE.
Daniel Meyer
The State of confusion.
« Reply #7 on: May 01, 2012, 09:17:28 AM »
Doesn't take many miles (bearing failure or alignment/4 nuts thing).
Lots of folks think it's all about the grease. The truth is if a bearing is failing or the pumpkin is not aligned, the grease is pretty much irrelevant.
Glad ya caught it!
CUAgain,
Daniel Meyer
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #8 on: May 01, 2012, 09:22:40 AM »
Some info on the Nilos Ring
Below is a bearing on the left as standard and on the right with a Nilos sitting on top of it.
Here is how it is installed. It's probably not necessary because the bearing is sealed but it provides an added degree of protection for the bearing seal in the absence of the lip seal that is lost for the "double bearing mod."
larswlvs
Akron,Ohio
« Reply #9 on: May 01, 2012, 10:35:00 AM »
Thanx everyone for the explanation of the nilos ring...I did not use one I will look into getting it
X Ring
« Reply #10 on: May 01, 2012, 10:39:13 AM »
It's not needed but for a couple bucks it is peace of mind.
Marty
FryeVRCCDS0067
Brazil, IN
« Reply #11 on: May 01, 2012, 11:38:35 AM »
Cool. Loss of the seal is the main reason I've haven't considered doing the mod.
NITRO
Eau Claire, WI
« Reply #12 on: May 01, 2012, 05:36:14 PM »
I did the double row switch about 10k ago and did not use the Nilos.
When in doubt, ride.
« Reply #13 on: May 02, 2012, 07:29:49 PM »
If you use a bearing cover (Nilos) then you need to cut the spacer down the correct thickness, or it will all be too wide to put back together.
