February 04, 2026, 10:41:29 PM *
Author Topic: swapping side stand  (Read 1458 times)
N0tac0p
« on: May 05, 2012, 04:14:18 AM »
ok seeing the lift adapter is positioned on the side stand frame, how the heck do u change it?
Joe Hummer
Arnold, MO
« Reply #1 on: May 05, 2012, 04:35:01 AM »
not sure what one you have...the ones i have installed is the pro-lift from ebay.  I put jack stands under the highway bars...then loosen the side stand bolts...and slip the adapter under the side stand bracket.  Tighten and use...
1999 Valkyrie Interstate
N0tac0p
« Reply #2 on: May 05, 2012, 05:43:52 AM »
i have teh adapter that lets you use that double arm mc lift
« Reply #3 on: May 05, 2012, 06:13:27 AM »
You dont need the bike on a lift to work on the kickstand......just upright
You can put jackstands or homemade stands under the engine guards, or simply place your lift under the forward part of the engine and only the front wheel will come up.......lift to the first safety and then work on the sidestand
« Last Edit: May 05, 2012, 06:15:47 AM by Chrisj CMA » Logged
N0tac0p
« Reply #4 on: May 05, 2012, 06:19:34 AM »
i thought you needed the adapter or you'd be lifting on the pipes?
« Reply #5 on: May 05, 2012, 06:26:13 AM »
try it and see....mine fits just fine (SEARS)
« Reply #6 on: May 05, 2012, 07:16:36 AM »
Some aftermarket pipes will interfere. If so, put a thin block of wood under the crankcase.
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: May 06, 2012, 10:33:48 AM »
You don't need the adapter to protect pipes. It's there because when the forward arm contacts the bottom of the motor the rear arm is still 4" or so from contacting anything.
Fred.
VRCCDS0237
