February 04, 2026, 10:41:32 PM *
Author Topic: crunch sound while ridding today  (Read 1334 times)
slider
mulberry arkansas
« on: May 05, 2012, 08:01:46 PM »
happened twice  sounded like some one crunched  a piece of class with a hammer,did not feel a thing thru handle bars,or foot pegs..the lady didnt miss a beat...didnt see any road trash   so..Im lost anyone ever have this happen??
a proud navy veteran
PhredValk
Edmonton, Alberta, Canada
« Reply #1 on: May 05, 2012, 10:11:03 PM »
I run a car tire, and when a stone lets loose inside the fender it sounds kinda like that. I suppose if there's rust in the rear shocks it might sound like that breaking off, but it would have to be a lot of rust.
I ran over a pop bottle once and got that sound. I would have seen it if the kid didn't have it hidden under his jacket.. Grin Grin Grin Grin
Fred.
VRCCDS0237
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: May 06, 2012, 04:06:20 AM »
Hopefully it's nothing.
Try another test ride, check for something stuck in your tires. If you have modified exhaust pull the clutch lever in and try some controlled heavy braking, if you here it again try to narrow down front or rear. Then try some hard left and right turns.
  I'm thinking could be brakes, wheel bearings, or nothing at all?
U-joint you will feel first before you here it. These are some things that have made noises for me, although I never experienced the noise you describe?
« Reply #3 on: May 06, 2012, 05:03:35 AM »
If you have a lift.  lift the rear, secure the bike, grab the lower (closest to the ground) part of the wheel/tire and try to move it side to side.  If you can feel evena  tiny movement like a "tic tic" then its a bad wheel bearing, probably left one.
