February 04, 2026, 09:16:45 PM *
Author Topic: Interste speedo malfuncton  (Read 1161 times)
Iroqouis
« on: May 07, 2012, 07:59:05 PM »
1999 interstate speeddo quit working.In past month it would not work for few minutes then work fine. stopped worrking all together Tested as per shop manual got reading .223 volts evan when pushing bike. I suspect the speed senser not sure though they are about 90.00 $ bike bandit.. wondering are these these prone to failer ? Anyone had any experiance with bad  sensers? thanks in advance for any help or sugestions you guys might have Dave M
hager the horrible
florence co
« Reply #1 on: May 07, 2012, 09:22:45 PM »
Had same problem on my 2000 interstate found it was the drive ring behind the drive gear the ears were no longer driving the drive gear the ring is located in the front wheel hub. Has 2 tabs that drive the gear box that drives the speed sensor if you want give me a call and i will tell you how to diagnose it just pm me for phone #
Momz
ABATE, AMA, & MRF rep.
« Reply #2 on: May 08, 2012, 05:31:28 AM »
That happened to me (2K I/S) and I bought the $90.00 sensor cable with no results.
Checked my 98 std. and it had the same drive unit.
Got a used drive unit from Pinwall for only $10.00 and now all is well.
ALWAYS QUESTION AUTHORITY!
cutter
Plantersville, Texas
« Reply #3 on: May 08, 2012, 06:03:20 AM »
Had that happen on my 99' I/S. Replaced the speedometer sensor, all better. When I took the sensor apart, I found water in it. Diect line has it for $71.93 part no. 37700-MBY-008 (replaces 37700-MBY-000) .
Michvalk
Remus, Mi
« Reply #4 on: May 08, 2012, 04:26:06 PM »
The sensor in my 99 Interstate went bad from water inside. I got a used one from Pinwall 6 years ago for 25.00 shipped, and no more problems cooldude
