February 04, 2026, 09:16:44 PM *
Author Topic: Clunk from accel to decel  (Read 1648 times)
WarrenK
Eau Galle, WI
« on: May 08, 2012, 08:07:08 AM »
I have recently noticed a clunk in the drive line when I throttle up or down (change from acceleration to deceleration) in any given gear.  I dont remember hearing this before, but do not think this is normal.  Undecided  Sound seems to be coming from area of u-joint.  Spline lube has always been done at normal intervals, I put new tire on recently and splines were just fine, have always tightened the last 4 bolts on final drive AFTER wheel installation, per instructions.   I have 52K on the clock- have pulled trailers.
There does not seem to be any vibration or unusual noises.  .  .  . but I suspect the u-joint.  Have ordered u-joint and boot-  am I on the right track?
Could there be other possible causes for the clunk?
Thx
« Reply #1 on: May 08, 2012, 08:11:14 AM »
You can inspect the u-joint be removing the rear brake pedal assembly and reservoir, pulling back the swingarm boot.
You can do this on the sidestand but lifting the rear tire allows better inspection practice.
« Last Edit: May 09, 2012, 06:28:37 AM by Ricky-D » Logged
Bone
« Reply #2 on: May 08, 2012, 09:37:39 AM »
About 2 hours ago I took my Valk out for a test drive. Just installed a new u-joint. I can't believe how much better it feels (drive train) when opening / closing the throttle and shifting. Wasn't sure it was a u-joint so I started removing one piece at a time. Was surprised how bad the u-joint was and still worked. Would have parked it much earlier if I knew it's condition.
Took 10 days to get the part through HDL but the price was good about $65.
Michvalk
Remus, Mi
« Reply #3 on: May 08, 2012, 04:23:10 PM »
The rubber dampners in the wheel can cause the clunk as well cooldude
Thunderbolt
Worthington Springs FL.
« Reply #4 on: May 08, 2012, 05:58:59 PM »
Probably U-joint, but could be dampers or splines.
WarrenK
Eau Galle, WI
« Reply #5 on: May 08, 2012, 06:23:54 PM »
Yes, thanks for the advice on the dampers.
I forgot to say, installed new dampers last winter and the old ones were done for!  Smiley
I will replace the u-joint soon, looks likely to be the problem.
I will post with results when done!
Thanks, all!
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: May 08, 2012, 10:56:51 PM »
Don't over look the brake calipers.  They float and have been known "clunk" under hard acceleration and braking.
Marty
shortleg
maryland
« Reply #7 on: May 09, 2012, 06:43:37 AM »
 Check pinyon cup and shaft also.
     Shortleg[Dave]
