February 05, 2026, 12:49:52 AM
? Adding a LED licence plate frame to my ST1300
Topic: ? Adding a LED licence plate frame to my ST1300 (Read 1265 times)
May 09, 2012, 02:22:34 PM »
It's going tob e like wiring in an octopus
There's wires going to each turn signal, runnign light and brake light.
I need to be able to remove the rear fender with licence plate attached for rear wheel removal.
What kind of connector can I use that I can unplug each time I remove the fender?
Re: ? Adding a LED licence plate frame to my ST1300
May 10, 2012, 08:10:52 AM »
I hope you get a better answer, but I know there's a whole stand of connector frobs at NAPA...
you could just pick one that you like.
I take my rear fender off to change my tires. I have to undo the tail-light connector, and it is
a lot like a Chinese puzzle...
amazngrace
Eastern Shore, Virginia
May 10, 2012, 05:42:27 PM »
Britman,
Try this place, they have just about everything:
http://www.vintageconnections.com/index.htm
...ED
99 Red and Black IS
Former BMW Guy
Aut viam inveniam aut faciam.
Apple Valley, MN
May 10, 2012, 05:58:22 PM »
Try your local Fastnall retail location.
Joe P
Motorcycling is not, of itself, inherently dangerous.
It is however, extremely unforgiving of: inattention, ignorance, incompetence or stupidity.
May 17, 2012, 01:49:01 PM »
I ended up uisng Posi Tap. What a gret easy way to do wiring splices (if that's the correct term).
http://www.posi-lock.com/posiplug.html
OK another question.
Using a volt meter how I do I check this thing to make sure the wiring isn't broken inside the unit?
It's a brake light flasher
