February 04, 2026, 10:36:37 PM *
Author Topic: 99 Valkyrie transmission trouble  (Read 1716 times)
Indiana Banana
« on: May 14, 2012, 01:03:53 PM »
My transmission started making a very loud noise yesterday, sounds like grear clanging. 54,000 miles, is this common with the Valkyrie?
Farther
Quimper Peninsula, WA
« Reply #1 on: May 14, 2012, 01:18:01 PM »
No!
~Farther
« Reply #2 on: May 14, 2012, 01:29:19 PM »
Are you sure it's the tranny? With those miles it may well be the u-joint.
Mr.BubblesVRCCDS0008
« Reply #3 on: May 14, 2012, 01:31:42 PM »
I'm with John on this valk trans. are very tough. You might want to post on the local board to see if someone is close to you to give you a hand.
Thunderbolt
Worthington Springs FL.
« Reply #4 on: May 14, 2012, 01:52:35 PM »
Probably the u-joint or rear splines.  I would take rear end apart, if not rear splines, take drive shaft and u-joint out and inspect all possible wear points.
Hoovey
Southern,Indiana
« Reply #5 on: May 14, 2012, 04:55:41 PM »
Where abouts in Indiana are you??
« Reply #6 on: May 14, 2012, 05:29:03 PM »
Lot of hoosiers popping up here lately!  cooldude
« Reply #7 on: May 14, 2012, 05:31:54 PM »
Maybe we can talk then into coming to the fall ride.
YoungPUP
Valparaiso, In
« Reply #8 on: May 14, 2012, 05:39:52 PM »
Where abouts are you in Indiana, and what were you doing when It started making the noise?  Is it constant or changing with RPM?
99 STD (Under construction)
« Reply #9 on: May 14, 2012, 08:42:54 PM »
Does it go away when using the clutch?
PhredValk
Edmonton, Alberta, Canada
« Reply #10 on: May 14, 2012, 11:44:29 PM »
Mine does some rough shifting, clatter that I can feel in the shift peg, especially shifting down thru neutral to first if I just push instead of jamming it down. Like the gears are not meshing correctly. Is this what you're hearing?
99 IS, 38K miles, it's always done this, though way less the first 1000 miles after oil changes.
Fred.
VRCCDS0237
