January 28, 2026, 06:26:40 PM *
Author Topic: stop lights/turn signals  (Read 3305 times)
franco6
Houston, TX
« on: May 26, 2009, 04:02:18 PM »
i d like to rig 2 more stop lights (small red bullets) and run them with the brake light.also rig the rear turn signals into running light/turn signal. any input would be appreciated.
Enjoy the ride!
junior
new hampshire
« Reply #1 on: May 26, 2009, 04:09:21 PM »
buy a set of front turn signals and ether paint the lenses red or get red bulbs  this will give you the 2 filiments that you need to make them run and turn, or if you have a sorce for red lenses that will fit the 97 lights please let me know
junior
« Reply #2 on: May 26, 2009, 04:33:43 PM »
For the turn signal mod, I went this route.....
http://www.valkyrieriders.com/shoptalk/ledturnsignalmod.htm
Bought 'em here.....
http://www.electricalconnection.com/other-lighting/tsk-star&sport.htm
Can't really tell much, but here's a short video on youtube of some guy (not me) that has 'em on his Valk.....
LED Running lights on a Honda Valkyriepowered by Aeva
« Reply #3 on: May 26, 2009, 06:31:05 PM »
There's also this from Chet's Rattlebars site....
http://www.rattlebars.com/mtz/signals.html
And this from the same site.....
http://www.rattlebars.com/mtz/redsignals.html
franco6
Houston, TX
« Reply #4 on: May 28, 2009, 09:55:37 AM »
 :cooldude:that s exellent! how much? thanks
Enjoy the ride!
Master Blaster
Deridder, Louisiana
« Reply #5 on: May 28, 2009, 10:43:36 AM »
In the early 2 screw lens signals you can replace te light socket with a double filiment one using JB weld or use a set of fronts on the rear.  If you replace, you will have to solder an extra ground wire to the socket. Using a trailer converter, you can make them into stop/turn/running lights.  You can get the cheap Blazer brand red marker lights at almost any auto parts store for a couple of bucks.  The lens just pops off and on on these, pop off the lens, rout out all of the base including the light socket out to the rim that the lens mounts on leaving a tab on each side to mount to the 2 screw fixture with shorter screws, then just pop the lens back on.  Easy and cheap.
Ken Tarver
North Mississippi
« Reply #6 on: May 28, 2009, 02:15:19 PM »
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/catID/16/scID/39/IMID/732
franco, I have this converter and like it very much.
Had the electrical connection converter on another valk....like the kury product much more.
You can paint the inside of the turn signal lenses with Testors Transparent Candy Apple Red model spray paint. Should look something like this.
ricoman
Sarasota, FL
« Reply #7 on: May 28, 2009, 03:09:42 PM »
buying two fronts and installing them on the rear is a good way to go. Get your running light power from the license plate light. Ground wires are the same as what you took off.
clear lenses with two screws are easy to find- a good way to get red (from a tip here or another forum, not my original idea) is to paint them with Testors transparent Candy Apple Red  from a hobby store. I did this about 3 weeks ago and the results are exactly what you are looking for. I went with 4 light coats of paint, letting it dry well between coats, and it matches the stock rear light. This will give you extra running lights with turn signals.
It will not give you extra brake lights. If you want run/turn/brake you will need a modulator such as the one from Kurykyn and you will not need to go through the hassle of changing lights, only lenses.
I added an LED mounted on the back of the sissy bar to get additional brake light, higher, and very visible from the rear.
« Last Edit: May 28, 2009, 03:14:41 PM by ricoman » Logged
« Reply #8 on: May 28, 2009, 04:03:07 PM »
franco......
The Electrical Connection kit usually runs about $49.95 or so.  I think that's what I paid for it if I remember correctly.
There are other options for adding lights to rear of the Valk too.  These people have lots and lots of cool ideas for adding lighting to your bike....as well as your other toys too.
http://www.customdynamics.com/motorcycle_lights.htm
« Last Edit: May 28, 2009, 04:21:00 PM by BeltSanders » Logged
Ken Tarver
North Mississippi
« Reply #9 on: May 28, 2009, 10:18:39 PM »
you CAN actually paint the inside of those amber lenses with the candy red.....they will be red when you are through, then you won't have to buy new ones.
I sprayed 3 light coats. The Kury kit gives you the brake light, and option to flash the brake 4 times, then steady on.
Ken
