February 05, 2026, 12:49:55 AM *
Author Topic: Opinions: The best carburetor sync tool  (Read 3309 times)
ryord
« on: May 21, 2012, 06:22:45 AM »
I would like some opinions on what you folks think the best apparatus is for synchronizing the Carbs on our Valkyrie's. I have seen some that use only 2 gauges other prefer 6. Please let me know. Thanks Rick
F6BANGER
Albuquerque NM
« Reply #1 on: May 21, 2012, 06:29:41 AM »
Six gauges are better than two. While adjusting one carb, you will see the other gauges moving around.
N0tac0p
« Reply #2 on: May 21, 2012, 07:02:41 AM »
I have an old 4 gaugee clsuter from my 76 wing.  is it possible to use that and sequesnt the sync?  if so, how?
« Reply #3 on: May 21, 2012, 07:03:50 AM »
I use a single gauge.. Simple and works just fine..
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #4 on: May 21, 2012, 07:10:35 AM »
I use the TwinMax systems gauge...it's simple and works great
If guns kill people where are mine hiding the bodies
frosty
« Reply #5 on: May 21, 2012, 07:26:36 AM »
Where might find the twinmax for the Valk carbs. And best price? Thanx
« Reply #6 on: May 21, 2012, 08:16:12 AM »
I have the old school mercury tubes I like it but to each his own.
9Ball
« Reply #7 on: May 21, 2012, 08:44:25 AM »
refer to the Honda service manual and you will get the instructions for your gauge setup....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
jrcody1127
« Reply #8 on: May 21, 2012, 12:35:48 PM »
hello
were do you connect the vac tubs on the valk carbs, when syncing carbs?
tank_post142
south florida
« Reply #9 on: May 21, 2012, 12:44:19 PM »
back side bottom of each intake manifold
I got a rock Sad
VRCCDS0246
biguglyman
Brockport, NY
« Reply #10 on: May 21, 2012, 12:58:51 PM »
I've read in m/c magazines that the best way to synch your carbs is with an exhaust gas analyzer.  Not sure where to get that done though...
Brian
Monroe, NC
« Reply #11 on: May 21, 2012, 04:47:40 PM »
+1 using a single gauge. This way you elliminate any descrepency in the gauge accuracy between gauges.
« Reply #12 on: May 21, 2012, 04:48:37 PM »
Can't sync carbs with a EGA you can adjust the mix though and they would be really good for the idle mix
Tim R
Sioux Falls, South Dakota
« Reply #13 on: May 21, 2012, 07:21:40 PM »
Morgan Carb Tune gets my vote. I love mine.
Dirty Dave
Montreal, Canada
« Reply #14 on: May 22, 2012, 12:00:03 PM »
Using a single gauge will give you an approximate adjustment as the vacuum changes as you adjust other carbs. You will see this using a multi gauge setup. I use the Moragn and have to double check even with the four gauges. Really good tool. You'll be a hit with your friends that don't have one!
It's weird being the same age as old people
Michvalk
Remus, Mi
« Reply #15 on: May 22, 2012, 03:29:43 PM »
I like the one at the dealers cooldude
N8171S
Marlboro, Mass
« Reply #16 on: May 22, 2012, 05:20:37 PM »
I use two of the JC Whitney mercury manometers.  This is two sets of 4 so I have two unused tubes.  Gets all 6 done at once.  Use a T on # 6 to keep vacuum to petcock.
larswlvs
Akron,Ohio
« Reply #17 on: May 22, 2012, 08:54:32 PM »
This is the TwinMax...
http://www.ascycles.com/detail.aspx?ID=2146
http://www.ibmwr.org/prodreview/twinmax.html
It's not real cheap  but it makes  synchronation so easy
fordmano
San Jose, CA.
« Reply #18 on: May 22, 2012, 11:58:23 PM »
I am kinda partial,,,
Yes I know there are 7 gauges, but that's the Eagle Scout in me "be prepaired" it's for possible failure or verification if needed.
So make your own.
powered by Aeva
They work great.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #19 on: May 23, 2012, 06:08:36 AM »
The best kind of tool would be the one where you can observe all six cylinders at the same time since it is a comparative adjustment that synchronizing is doing.
BamaDrifter64
Athens, Alabama
« Reply #20 on: May 23, 2012, 07:06:20 AM »
Lars-
Is there a certain procedure to follow with the TwinMax to do all 6 carbs equally, or do you just do each carb individually?
Dave
wild6
(Old enough to know better)
Vernon, NJ
« Reply #21 on: May 23, 2012, 10:34:29 AM »
A do-it-yourself tool for this method: http://www.valkyrieforum.com/bbs/index.php/topic,3863.msg28841.html#msg28841
« Reply #22 on: May 23, 2012, 11:20:34 AM »
Here's the one I made.
whitestroke
San Pedro, Ca.
« Reply #23 on: May 23, 2012, 09:39:14 PM »
Video of synced gauges and sound of 2 brothers 6 into 6 exhaust.
http://www.youtube.com/embed/1imfVbe9V7w
On sale at Harbor Freight $10. each.
« Last Edit: May 23, 2012, 09:42:53 PM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
