February 05, 2026, 12:54:20 AM *
Author Topic: Oil -- Circle on back side of label . . .  (Read 1247 times)
sheets
Jct Rte 299 & 96, Calif.
« on: May 22, 2012, 06:14:06 PM »
I know the appropriate oil for the Valk, the bottom of the circle should be blank. I noticed something different today when cruising the oil aisle. Thought the insignia on the reverse side used to say "Energy Conserving" in the lower portion. The ones I looked at today say "Resource Conserving". Is that reference/meaning one in the same? Curious what the latest and greatest is.
« Last Edit: May 22, 2012, 06:45:57 PM by sheets » Logged
BonS
Blue Springs, MO
« Reply #1 on: May 22, 2012, 06:36:49 PM »
I think that means that it contains recycled oil.
sheets
« Reply #2 on: May 22, 2012, 06:49:05 PM »
I don't recall seeing anything on the various label brands stating anything about recycled oil content. All the major brands -- in that location, some were blank while all others said "Resource . . . ".
chrise2469
Winnipeg Manitoba Canada
« Reply #3 on: May 22, 2012, 07:42:16 PM »
From the API site:
3. RESOURCE CONSERVING or ENERGY CONSERVING
These designations apply to oils intended for gasoline-engine cars,
vans, and light trucks. Widespread use of “Resource Conserving”
or “Energy Conserving” oils may result in an overall savings of fuel
in the vehicle fleet as a whole
http://www.api.org/certifications/engineoil/categories/upload/motor_oil_guide_2010_120210.pdf
I would not advise using this is a wet clutch such as the valkyrie. YMMV, not a professional engineer, and I haven't stayed at a holiday inn express lately.
sheets
« Reply #4 on: May 22, 2012, 08:09:36 PM »
Okay, thanks. I know we don't use the energy or resource conserving labeled oil in our bikes. I simply had not seen the term "resource" conserving before.  Appears that energy conserving and resource conserving are one in the same.  A new one on me. Now I know the rest of the story.  sheets
