January 28, 2026, 06:26:54 PM *
Author Topic: Oil Level - Progressive Front Fork Springs  (Read 2938 times)
humshark
Spring Hill Tennessee
« on: May 26, 2009, 11:52:27 PM »
99 Interstate -
I had progressive front springs installed 1 year ago. ( LOVE THEM ) I am leaking front oil again ( 2wice now ) since the original change.  The first time - the forks leaked immediately and within a month I had the shop redo the repair up in WI.
I have since moved to TN and I am leaking again.  Couple of questions -
Whats the official word on the oil level / amount needed when running the progressive springs?
Do i need the special tool if I decide to try this myself?  Do i need any special tools?
Is anyone around in the TN Thompsons Station / Spring Hill area familiar with changing the seals?
Thanks up front !
99 Interstate
05 FJR
97 Vulcan '88' Hacked
MP
North Dakota
« Reply #1 on: May 27, 2009, 03:59:49 AM »
I have 10,000 on front progressives.  I filled to shop manual level, but I understand some use a little less oil. No problems.
Fill with forks FULLY compressed.
I would guess you have a little tiny imperfection on your slider, and it slowly eats up the seal.  Need to smooth that off.
MP
"Ridin' with Cycho"
roadmap
« Reply #2 on: May 27, 2009, 04:33:15 AM »
try 2o/z less then the minimal amount i did it that way and so far no leak. i used to fill to the max amount but always came back and leak a yr or so later.   just put less in there the next time. i think there's more to the progressive springs. so a little less won't hurt a thing
Dag
Country Rep. Norway
« Reply #3 on: May 27, 2009, 04:43:43 AM »
99 Interstate -
Thanks up front !
You will find some details here:  http://www.valkyrienorway.com/forksprings.html
Dodis
'98 Blue & Cream
Texas City, TX
« Reply #4 on: May 27, 2009, 08:20:17 AM »
Same here. Installed Progressives last July, then in Feb over compressed the forks when trailering and caused a major leak on the right side (my fault). Replaced the seals and refilled with 1 oz less (like last July), and 1 month later it's leaking again  Angry . I saw no scratches or imperfections on the slider, and after the first rebuild, had no leak problems (till I messed up). Now it just started on it's own.
I am waiting on ANOTHER set of seals to arrive, and I am thinking of ordering some Bel-Ray oil for both forks, since they claim to have "seal swell" to help prevent leaking (thinking maybe 15 wt too). And, of course, I will thoroughly inspect the sliders to make sure there are no scratches. Might even polish them to be sure...
VRCC# 27132
mr_dodis(a)yahoo.com
DS#513 GY-TT 205/60   (still waiting for my cookie!)
humshark
« Reply #5 on: May 27, 2009, 08:43:55 AM »
I had someone say - I can't remember where or when that i wouldn't need the special tool for replacing the fork seals.  Is this correct?  Can i do this myself with a standard compliment of tools?
If anyone is in the Nashville TN area I'd be interested in hooking up to do the work.
99 Interstate
05 FJR
