February 05, 2026, 02:42:25 AM *
Author Topic: High Heat Paint  (Read 2187 times)
G-Man
White Plains, NY
« on: May 24, 2012, 08:09:39 AM »
I remeber that some members painted their pipes with a high heat "stove' paint.  I specifically remember that Smokin' Joe said that he was retouching up the paint regularly.  While looking at wheels, I came across this product and wondered if this would be a good alternative to the stove paint.  Comes in lots of colors.  Was thinking about painting the three pipes coming off of the engine black.
http://www.andysautosport.com/mercury/2005_2007_montego/brakes/caliper_paint/g2/g2g200163925.html
keepinon
New Caney, Tx
« Reply #1 on: May 24, 2012, 08:50:26 AM »
Been thinking on trying to paint an old set of 6x6's that have a lot of rust specks and blued badly. What I've found so far, but haven't tried yet,
http://www.kbs-coatings.com/Xtreme-Temperature-Coating.html
http://www.vhtpaint.com/products/flameproof/
Would also like other options/opinions on how to.
1998 GL1500 CT Trike
olddog1946
Moses Lake, Wa
« Reply #2 on: May 24, 2012, 08:59:43 AM »
That KBS stuff looks pretty promising. I have used wally world barbecue grill paint on a set of headers I put on My S10 pickup and they still look pretty good after 5 years. Which is longer than any header paint I ever used.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #3 on: May 24, 2012, 06:27:05 PM »
I used Rust-Oleum 1500 degree stove/grill paint and yes I have to touch them up from time to time. I bought a qt. can at Wally World for about $13.00 and still have 3/4 of a can.
« Last Edit: May 24, 2012, 06:29:17 PM by Smokinjoe-VRCCDS#0005 » Logged
keepinon
New Caney, Tx
« Reply #4 on: May 24, 2012, 07:42:48 PM »
Joe, did you use any special prep before painting?
Beautiful bike.
« Reply #5 on: May 24, 2012, 08:01:12 PM »
Beautiful bike.
Wire brush in my drill to clean it up then just applied the paint with a cheap hobbie paint brush. It smooth's out nice and looks alot better than the blue rust I had before doing this.
Bugslayer
Lubbock, Texas
« Reply #6 on: May 24, 2012, 09:08:26 PM »
I used Rust-Oleum "High Heat 2000*F " spray paint. I used a wire wheel on my bench grinder to prep the headers. For me, it was easier to hold on to each separate pipe and work it against the bench grinder/wire wheel. I taped each pipe and hung them up in the garage to paint. The paint has held up very well.
Before & after prep.
Grumpy
Tampa, Fl
« Reply #7 on: May 24, 2012, 09:08:38 PM »
Got one word cerma chrome, high temp ceramic powder coating. Had the pipes on a v-twin done last year, still look like polished stainless steel. A friend had the exhaust done on his Rv-4 aircraft, all the headers, muffler and down pipes, those endure some high heat, still look like new. Cost me $55 to do the honda twin, and $250 for all the tubes on the airplane. stuff is rated for 2000 degrees, not going to damage it, pipes would probably melt first.
« Reply #8 on: May 27, 2012, 06:31:41 PM »
I had these ceramic coated many years ago they still look good...Cost back then was around $150.00.
G-Man
White Plains, NY
« Reply #9 on: May 29, 2012, 11:52:38 AM »
Thanks All!   cooldude cooldude
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #10 on: June 01, 2012, 08:51:10 AM »
Contacted the seller of the G2 Caliper paint.  Their response,,
Hello,
This holds up to temperatures around 980 degrees.
"G2™ has specially contracted chemical engineers to research and develop our two-part paint which now offers the highest heat resistance on the DIY aftermarket (up to 980 degrees)."
Thank you for your interest,
Now, what's the temp of a Valkyrie header pipe?   ???
Bugslayer
Lubbock, Texas
« Reply #11 on: June 01, 2012, 10:30:30 AM »
About a year ago, I checked the temp's on my TBR 6/into/6. I checked them after several rides with the motor still running. I used a lazer thermometer and checked the temp just below the flange's . The hottest temp I found was 540*. I also found the pipes towards the front of the motor ran a little cooler (480-500*) than the back pipes.
I'm going to assume that stock pipes (double walled) will run cooler than my single wall TBR's.
Gear Jammer
Magnolia, Texas
« Reply #12 on: June 01, 2012, 05:15:43 PM »
Thanks Bugslayer  cooldude
« Reply #13 on: June 01, 2012, 05:56:23 PM »
More cermic coating that's chrome like.
http://www.eastcoastpowdercoating.com/Gallery_Ceramic_Chrome.htm
My rides:
