March 31, 2026, 06:59:46 PM *
Author Topic: Help needed?? In Albuqurque - leaking fork seal...(at least I think it is)...  (Read 1035 times)
gordorad
Washington, MO
« on: May 24, 2012, 12:55:00 PM »
Hey Bros!!!  Realized today I believe my right upper fork seal is leaking.
Anyone in the Albuquerque area that can lend a hand??  I'll be arriving in a few hours and spending at least the night and maybe more depending on the severity of this problem.
1)......Does this require immediate attention?  It's not pouring out, but is noticeable as the oil is picking up dirt....
2)  What is entailed in the repair?  Easy?  Hard?
Thanks in advance for the info!!
I'll be checking back in a few hours so if anyone is in the area or can lend a hand, let me know!!
Gordo
Support the Arts!!    www.gordonradfordphotography.com
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: May 24, 2012, 01:03:23 PM »
Definitely not an emergency repair. I tied a red shop rag around the slider to catch the leaking oil. It worked so well that I stayed lazy and fixed it about 20,000 miles later. The repair is doable as I did my own.
« Reply #2 on: May 24, 2012, 01:14:58 PM »
Not emergency unless it's just gushing. I let mine go for  Embarrassed about a year before I finally got the fork seals replaced.
9Ball
« Reply #3 on: May 24, 2012, 01:25:46 PM »
just make sure the fork oil isn't getting on the brake pads or rotor....the rag trick (mentioned above) will get you home.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Daniel Meyer
The State of confusion.
« Reply #4 on: May 24, 2012, 02:07:28 PM »
And the oil really won't hurt the pads any or seriously effect your braking. Just a mess to clean up.
CUAgain,
Daniel Meyer
SCain
Rio Rancho, NM
« Reply #5 on: May 24, 2012, 02:22:14 PM »
Gordo,
Give me a call when you get in and let me know the status of the leak and your plans. I have never done the seal myself but willing to give a hand if I can. I also know all the shops here in town. I live in Rio Rancho, just outside Abq. You might try the film negative trick, just a thought.
My # is 505-Four Zero One-739 One
Steve
Steve
Slick
Jupiter, Florida
« Reply #6 on: May 24, 2012, 03:31:11 PM »
Film negative trick worked like a charm for me-- worth a shot
1999 Valkyrie Interstate,
2003 1800 VTX
gordorad
Washington, MO
« Reply #7 on: May 24, 2012, 05:29:16 PM »
Many thanks to all who responded, and to F6 Banger who called me and also told me about the film trick.
A few years ago, I would have had a plethora of film to select from for the repair...But no more as it's all zeros and ones........
I didn't realize that the NM ride was this weekend.  Looks like I"m might be joining as I'm in the "Q" and headed north tomorrow!!
G.
« Reply #8 on: May 24, 2012, 06:12:42 PM »
Dentist can also give you plastic strips if you ask
Worked for me for a year
F6BANGER
Albuquerque NM
« Reply #9 on: May 24, 2012, 06:57:59 PM »
G.
