March 31, 2026, 06:57:59 PM *
Author Topic: Issue with dark side??  (Read 1455 times)
ohshooter
« on: May 25, 2012, 06:44:11 AM »
I convert my 01 intersate over to the dark side last summer. I installed a General Alrimax and then changed the front to a Avon Cobra. I have been very please with it except I have an issue now when I reach 110 mph I start  to become unstable, I develope a slow wobble. Before I went darkside I'd been up to 120 - 125 with no wobble. Anybody else run into this issue?? I'm running between 30 and 35 psi. Any comments ??
gordorad
Washington, MO
« Reply #1 on: May 25, 2012, 06:50:55 AM »
Slow down!!
Support the Arts!!    www.gordonradfordphotography.com
Ice
On a road less traveled.
« Reply #2 on: May 25, 2012, 06:58:10 AM »
Slow down!!
+1  cooldude
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #3 on: May 25, 2012, 06:59:31 AM »
Might check shock bushings.
Could check the steering head bearings.
Maybe adjust the PSI on either front or rear or both.
I run 41 in my Altimax rear and 41 in my Metzler in the front on my Interstate.
My IS is a little like that too though... it's a little drifty at triple digit speeds.  My Standard isn't though.  I always figured it was the fairing.
Jabba
csj
Peterborough Ontario Canada
« Reply #4 on: May 25, 2012, 07:20:37 AM »
I've had that wobble happen on two occasions, and the fix was
new shock bushings. The stock rubber ones seem to last a very
short time, I'll soon be looking for the urethane type.
Got up to triple digits last night, new bushings, not even a bit
of wobble.
vanagon40
Greenwood, IN
« Reply #5 on: May 25, 2012, 09:14:29 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,5645.0.html
Check out the above thread for similar issues and comments.
signart
Crossville, Tennessee
« Reply #6 on: May 25, 2012, 09:23:01 AM »
Is that c/t speed rated?
« Reply #7 on: May 25, 2012, 11:34:34 AM »
General Altimax and first a Metz 880 now a Shinko 890. Wink Slow speed wobble and my high speed wobble always came back to the shock bushings, uglystupid2 It can be very disconcerting at the triple digit range. Angry Look at the upper shock bolt and if it ain't centered you found yer problem. cooldude RIDE SAFE.
BigAl
« Reply #8 on: May 25, 2012, 01:26:44 PM »
THe Motorcycle quiet possibly could need a motorcycle specific tire.
Engineering was expensive for your bike from the factory side.
Maybe you should take them at thier word that you should not have a car tire on your motorcycle.
But that.s just me.
« Reply #9 on: May 25, 2012, 01:49:27 PM »
IF it is the tires, it will be the front cobra, not the car tire causing the wobble.
Pete the Greek
« Reply #10 on: May 25, 2012, 02:23:53 PM »
i run 40 lbs in my darkside, different brand tires run better at different lbs, have an Avon fron and have been 130mph like on a rail! Even though i'm a slow rider usually!
have it rebalenced the front that is and check to see it wasn't installed "Back waards" like they did my buddies stratoliner although some guys run rear tires backwards on the front?! and love it
BigAl
« Reply #11 on: May 25, 2012, 04:55:37 PM »
SO why would installing it back wards make a difference, if your buddy likes his backwards? And Swares by it.
BigAl
« Reply #12 on: May 25, 2012, 04:57:01 PM »
The last change was the front tire.
I hope that front tire you installed was in fact a Radial.
If not there is your problem.
ricoman
Sarasota, FL
« Reply #13 on: May 25, 2012, 05:40:06 PM »
Slow down!!
or leave a few minutes earlier so you don't have to haul a$$
Jess Tolbirt
White Bluff, Tn.
« Reply #14 on: May 25, 2012, 08:23:11 PM »
maybe the car tire is bouncing side to side,, sorta like a boat doing a prop walk...just right on the edge of wiping out...
Valkyrie member # 23084
Jess Tolbirt
White Bluff, Tn.
« Reply #15 on: May 25, 2012, 08:23:47 PM »
o yea one other thing,,, SLOW THE F*** DOWN!!!!!!!!!
Paxton
So Cal
« Reply #16 on: May 25, 2012, 08:26:33 PM »
If you slow down to 119 MPH, your challenge is met! 2funny
I run my front tire @ 44 PSI and the CT @ 28 PSI. It feels like a Limousine @ 101 MPH... for no more than 5 seconds! Cheesy Shocked Lips Sealed
She commands my respect! Embarrassed Cheesy  My usual "speed" on the slab is 3-3.25K RPM. If I am in a real hurry, I might cruise @ 85-90 MPH.angel
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
Momz
ABATE, AMA, & MRF rep.
« Reply #17 on: May 25, 2012, 08:59:06 PM »
Your wobble wil dissappear if you could wrangle a CT in front and run an Avon in the reverse direction in the rear.
But ultimately your low speed handing would be sevrely comprimised. 2funny
ALWAYS QUESTION AUTHORITY!
Steve K (IA)
Cedar Rapids, Iowa
« Reply #18 on: May 25, 2012, 09:09:12 PM »
But that.s just me.
Very wise words.   Wink
I gave a C/T a 4000 mile chance.
Handling was severely compromised.
Never again!  crazy2
Motorcycles were not made to use a C/T.
States I Have Ridden In
Reb
Greeneville, TN
« Reply #19 on: May 25, 2012, 11:40:37 PM »
Shock Bushings, or double check to make sure both shock are on the same setting.
2022 Honda Goldwing Tour DCT
1999 Honda Valkyrie IS
1972 Honda CB350F
1978 Honda CB550K
1968 Honda CL175 Sloper
alph
Eau Claire, WI.
« Reply #20 on: May 26, 2012, 02:08:36 AM »
Try going a little faster.  I had an old Toyota that had a bad shimmy at 75 but when you got to 80 it plained out smoothly.  Try 130 or something...... Cheesy
RiderNJ
'99 I/S Black and Chrome
Southern New Jersey
« Reply #21 on: May 26, 2012, 06:37:33 AM »
I'm with Alph, if it wobbles- give it more throttle.
 Grin
"Our real problem, then, is not our strength today; it is rather the vital necessity of action today to ensure our strength tomorrow." Dwight D. Eisenhower
MacDragon
My first Valk VRCC# 32095
Middleton, Mass.
« Reply #22 on: May 26, 2012, 06:52:28 AM »
After 100 mph... you're not driving it, you're aiming it... 2funny
Patriot Guard Riders
BigAl
« Reply #23 on: May 26, 2012, 07:33:29 AM »
Both of the Valkyries I owned had excellent handling.
Great stopping power.
Smooth at 100mph on any surface.
Yes I ran a E-3, a Avon Venom-R and a Avon Cobra. Even ran a Bridgestone that was smoother than silk. Metzler that slid all over the place on dry roads.
But I rode two bikes with car tires and what the hell are you thinking .
They ride like SHxxxxxxxx and that is putting it mildly.
