March 31, 2026, 06:59:50 PM *
Author Topic: stebel horns anybody?  (Read 1484 times)
wdvalk
Katy Texas
« on: May 25, 2012, 03:33:30 PM »
anybody have some pics of where you mounted you stebel horn,thanks
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: May 25, 2012, 03:43:06 PM »
I took a piece of angle iron a few inches long and bolted it to the kick stand bolt underneath
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
« Reply #2 on: May 25, 2012, 03:44:21 PM »
I had a void where the fuel selector was when I converted to a Pingel, so I plugged the hole with a Stebil
Super Santa
VRCC #27029
Houston, Texas
« Reply #3 on: May 25, 2012, 04:33:25 PM »
I mounted mine in my Interstate pod.  If you don't have an Interstate that might be difficult.
DavRed
Buckeye AZ
Phoenix AZ
« Reply #4 on: May 25, 2012, 06:11:35 PM »
+1 cooldude
One on each side.
and Big BF Quads. Sounds like 4 old Fords fixen to get ya.... Grin
OverdueBill
Elkmont, Alabama
« Reply #5 on: May 25, 2012, 07:57:31 PM »
Mounted on the permenant jack adaptor.  Stole the idea from someone on this site.  Thanks for the idea!
X Ring
VRCC #27389, VRCCDS #204
« Reply #6 on: May 25, 2012, 09:09:16 PM »
Me too!
Marty
Divot
Retired - VRCC #30489
Boise, Idaho
« Reply #7 on: May 25, 2012, 09:42:04 PM »
Same place as Chris and Marty, only difference is mine is turned sideways to still allow easy access to the OEM petcock.
2000 GL1500C - Black
1980 Honda 185 XL
Sodbuster
« Reply #8 on: May 26, 2012, 05:12:04 AM »
You are welcome   Wink
VRCC # 30938
« Reply #9 on: May 26, 2012, 05:19:43 AM »
Me too!
Marty
Same here!  Hoser
texaninsouthfl
Serving those who served us...
East Lake County, Florida
« Reply #10 on: May 26, 2012, 08:17:45 AM »
I don't have a picture at the moment but I mounted my Stebel to the stock horn mount. I found a little "L" bracket and it bolted right up. I will eventually find a little thicker (stiffer) bracket because it wiggles a little bit on bouncy roads, but it was the easiest place to mount and it's right out where it can be heard.  For the record, IMHO, the Stebel is the best "honk" for the buck. It's stupid loud and I'm pretty sure I've caused more than one cage driver to crap their pants.
Mr. Nuts
Bitterroot Valley Montana
« Reply #11 on: May 26, 2012, 08:33:26 AM »
Two heavy zip ties figure eighted and hung underneath by kickstand has worked great for me for 6-7 years now.
“Speed has never killed anyone.... Suddenly becoming stationary, thats what gets you.” - Jeremy Clarkson
Raverez
No good deed goes unpunished
Central New York State
« Reply #12 on: May 26, 2012, 08:53:07 AM »
Is there a way to mount it between the forks under the triple tree on an Interstae?
« Reply #13 on: May 26, 2012, 10:06:14 AM »
  If you get that figured out let me know please and T I A. 2funny I found a piece of angle iron in my shop that i cut down to size and mounted it where the original horn was mounted. Wink I have the exit of the horn ppointed down at the pavement. coolsmiley It will get your attention when i use it. cooldude RIDE SAFE.
« Reply #14 on: May 26, 2012, 10:42:03 AM »
If you take a hard hit on the forks you'll probably ruin the fender. Not much room when the forks are fully compressed.
« Reply #15 on: May 26, 2012, 11:28:22 AM »
I have the Fiamm horns and mounted mine under the side covers. nothing visable the compressor is mounted next to the bank sensor
chrise2469
Winnipeg Manitoba Canada
« Reply #16 on: May 26, 2012, 04:46:24 PM »
+1 to what Sandy said about compression.  Its also a bad place to mount because it faces forward direct into any rain and other stuff (bugs, debris etc).  The stebel compressor is supposed to be mounted mostly vertical.
Mines mounted on the clutch side
