January 28, 2026, 06:27:01 PM *
Author Topic: clutch basket  (Read 2305 times)
Wags
« on: May 27, 2009, 08:04:40 AM »
I'm about to tear into my clutch on my 1999 Interstate. Doing research and reading the service manual. I have one question. Is it necessary to remove the clutch basket? Or is it easier to remove the basket and use it as a temporary alignment tool for the plates? Or do I simply line up the plates in a stack, secure the stack then install into the basket?
Wags
Jeff K
« Reply #1 on: May 27, 2009, 08:33:05 AM »
No need to remove the basket unless its damaged.
I use a a rig like this to hold tension on the plates, then I put it into the basket to line them up good with less tension. Then I go back and install the spring. If they aren't lined up well its a bear to reinstall.
http://jkozloski.com/pics2/clutch/Clutch%20101.htm
Wags
« Reply #2 on: May 27, 2009, 09:17:17 AM »
Thanks Jeff!
I
chrise2469
Winnipeg Manitoba Canada
« Reply #3 on: May 27, 2009, 09:35:03 AM »
Here's a video of the clutch going into the outer.  i did the same thing as Jeff k and used the 1/4 pipe couplers.
https://contour.com/stories/mounting-clutch-into-a-valkyrie
I've also got some other vids I was going to link up as a tutorial.  Mine went back together last thursday.
Good luck.
« Last Edit: April 23, 2012, 05:18:03 PM by chrise2469 » Logged
