« on: May 28, 2012, 12:44:20 PM » |
« Reply #1 on: May 28, 2012, 01:08:36 PM » |
You sure have great quarters to work on your Valk.  How many miles were on the original dampners?
TennX
« Reply #2 on: May 28, 2012, 01:18:21 PM » |
You sure have great quarters to work on your Valk. How many miles were on the original dampners?[/i][/u] Yes inquiring minds would like to know, I wish the rims on my soon to be purchased Tourer looked that good....
« Reply #3 on: May 28, 2012, 01:28:47 PM » |
You sure have great quarters to work on your Valk.  How many miles were on the original dampners? I changed out the originals a few years ago. I think these ones had 50K or so on them. They werent too bad but I had some of the better ones with the metal part molded in, so I thought Id see if it tightend things up a bit That is the original Wheel from the factory.......the bike has 130K that wheel has just over 100K on it....I gave a clue in the picture what I use to keep it that way.........Blue Magic. But I did go through one bottle of Bombs Away and that stuff set me on course for easy maintenance
« Last Edit: May 28, 2012, 01:31:23 PM by Chrisj CMA »
« Reply #5 on: May 28, 2012, 07:29:31 PM » |
Jeff.....what are the "better" ones......Gary's?
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
olddog1946
« Reply #6 on: May 28, 2012, 07:34:11 PM » |
Jeff.....what are the "better" ones......Gary's? I believe he's talking about the 2000 and up Valk dampers..but Gary's would work, lol
VRCC # 32473 US AIR FORCE E7, Retired 1965-1988 01 Valk Std. 02 BMW k1200LTE 65 Chevelle coupe, 1986 Mazda RX-7 with 350/5spd, 1983 Mazda RX-7 with FOMOCO 302/AOD project, 95 Mustang GT Convertible 5.0, 5 spd Moses Lake, Wa. 509-760-6382 if you need help
« Reply #7 on: May 28, 2012, 07:51:24 PM » |
Jeff.....what are the "better" ones......Gary's? Bruce, the older ones had a piece of rubber with a hole and a seperate metal part that sat in the hole........it gets loose after awhile. The newer ones are one piece molded together so theres no wiggling between the rubber and the metal...............Sure did tighten up the drive train slop....I likes it a lot
« Reply #8 on: May 28, 2012, 08:21:10 PM » |
Are they different part numbers? It sounds like something I need to stock up on for future maintainence fun.
X Ring
VRCC #27389, VRCCDS #204
« Reply #9 on: May 28, 2012, 09:03:38 PM » |
Are they different part numbers? It sounds like something I need to stock up on for future maintainence fun.  Easy. Buy the ones for an I/S. Marty
« Reply #10 on: May 29, 2012, 06:32:02 AM » |
Are they different part numbers? It sounds like something I need to stock up on for future maintainence fun.  Easy. Buy the ones for an I/S. Marty Looking at the fishe for the 1997C and the 2000CF (stnd/IS) the pictures are different but the part numbers are the same. I would order on the phone and get confirmation, the parts could be randomly stocked so you could get either one if they have both on hand. HDL has always worked with me on the phone to satisfy what I needed.
« Last Edit: May 29, 2012, 06:35:35 AM by Chrisj CMA »
X Ring
« Reply #11 on: May 29, 2012, 06:44:29 AM » |
Are they different part numbers? It sounds like something I need to stock up on for future maintainence fun.  Easy. Buy the ones for an I/S. Marty Looking at the fishe for the 1997C and the 2000CF (stnd/IS) the pictures are different but the part numbers are the same. I would order on the phone and get confirmation, the parts could be randomly stocked so you could get either one if they have both on hand. HDL has always worked with me on the phone to satisfy what I needed. According to HDL's microfiche the 97 part # is 06410-MZ0-000 with the insert being part # 41242-MR5-000. The part # for an I/S is 06410-MBH-000. Marty
« Reply #12 on: May 29, 2012, 01:03:24 PM » |
Are they different part numbers? It sounds like something I need to stock up on for future maintainence fun.  Easy. Buy the ones for an I/S. Marty Looking at the fishe for the 1997C and the 2000CF (stnd/IS) the pictures are different but the part numbers are the same. I would order on the phone and get confirmation, the parts could be randomly stocked so you could get either one if they have both on hand. HDL has always worked with me on the phone to satisfy what I needed. According to HDL's microfiche the 97 part # is 06410-MZ0-000 with the insert being part # 41242-MR5-000. The part # for an I/S is 06410-MBH-000. Marty Makes sense because the picture was different, I probably looked at the numbers too fast
X Ring
« Reply #13 on: May 29, 2012, 04:13:08 PM » |
Only thing different are the 3 middle characters. It's easy to do.
Marty
