February 05, 2026, 02:42:35 AM *
Author Topic: FUEL FILTER  (Read 1645 times)
pocobubba
Pocomoke , Md
« on: May 30, 2012, 06:00:12 PM »
Can anyone recommend an external fuel filter ? I tried a purolator  clear plastic with a paper filter in it but it didn't let enough fuel gravity feed through it . I know there isn't much room ,I've desmogged and have a Pingel petcock, Dan Marc shut off valve, and Motion Pro fuel line ordered . I would  like to install the inline when I put it all back together . Thanks
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: May 30, 2012, 06:40:06 PM »
RM Works includes a Wix 33027 with their belly tank.  It's a metal small diameter.  You could give that one a try.
Marty
ryord
« Reply #2 on: May 30, 2012, 06:44:02 PM »
I am using the pingel inline filter and has worked great with a Golan petcock.
John U.
Southern Delaware
« Reply #3 on: May 30, 2012, 08:36:31 PM »
Golan makes fuel filters as well. They claim 10 microns if I recall correctly. I've been using them on two Valks with no starvation problems.
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #4 on: May 31, 2012, 02:21:07 AM »
I also run a Golan micro filter and their petcock, no problems.
vanagon40
Greenwood, IN
« Reply #5 on: May 31, 2012, 07:07:59 PM »
I have a Purolator (Champion) FF1203 (OEM F10024).  I believe others have used this successfully.
« Reply #6 on: June 01, 2012, 07:28:33 AM »
I use a Pingle valve with a plain ole in-line metal filter, usually a Fram, with no problems.. The OEM fuel line diameter is I believe 8. 'something' mm which is larger than 5/16" so I 'force fit' a 3/8" filter..
I feel most fuel flow issues come from lines that are left too long causing bows, kinks or some other type of 'warpage' to restrict the flow..
pocobubba
Pocomoke , Md
« Reply #7 on: June 01, 2012, 11:01:50 AM »
Thanks to everyone the tips .
valkyriemc
NE Florida
« Reply #8 on: June 03, 2012, 12:08:27 PM »
This may help;
http://www.valkyrieforum.com/bbs/index.php/topic,12961.msg109036.html#msg109036
Veteran USN '70-'76
shooter64
« Reply #9 on: June 03, 2012, 04:34:38 PM »
Just make sure what ever kind of fuel shut off you have comes after the filter. (Between the filter and the carbs) I made the mistake of installing a clear filter in the fuel line AFTER the petcock shut off. In other words, when I shut the petcock off there was still a big filter full of fuel that had already been admitted past the petcock and caused a hydrolock. I did that when I only had the bike a few days and had not read the potential problems that I later learned here. Thank goodness I had no damage and just took the plugs out, flushed the cylinders, changed the oil, and went back to using the standard filter that came with it.
« Last Edit: June 03, 2012, 04:37:31 PM by shooter64 » Logged
Columbia, S.C.
