March 31, 2026, 10:35:20 PM *
Author Topic: Question re. Dyna Beads.  (Read 585 times)
« on: May 31, 2012, 05:52:35 PM »
First, don't know if this should be in the Tech section or not since it's not Valk related. I have one new tire that the Toyota dealer can't seem to get balanced. The biggest problem is these new fangled balancers that don't spin it up fast enough, wish I could find someone with a unit that balances the wheels on the car. Those were the most accurate systems I've ever used but just try finding one these days. So, my question is....how many ounces of beads do you use in the tire of an SUV?  I don't get any vibration until I'm approaching 75 mph, and of course the balancers never spin them that fast.
« Reply #1 on: May 31, 2012, 05:59:32 PM »
John,
Follow this link
http://www.valkyrieforum.com/bbs/index.php/topic,7832.0.html
go to reply #2, read it and follow the link there to purchase them in bulk.  The innovative balancing link in reply 1 has a guide that tells you how much for various tires.  I use 3 oz in a car tire on the valk.
MNBill
Southern Minnesota
« Reply #2 on: May 31, 2012, 06:09:10 PM »
I had a tire that did that, I watched them balance it and you could see the tread was not round. They replaced the tire, actually 3 of them, they said the belts were broken in the tires. They were almost new tires.
MNBill
SE Minnesota
« Reply #3 on: May 31, 2012, 06:19:07 PM »
I agree, if they can't balance it by spin balance, it has problems.
« Reply #4 on: May 31, 2012, 06:24:32 PM »
I'll probably just take it back and lay it on the line with them. They've tried balancing it twice already with the same results so I think it's time for a new one. These are fairly new tires as well and weren't cheap.
