February 05, 2026, 02:43:35 AM *
Author Topic: How to safely change shocks?  (Read 2188 times)
localyokel
Newport Beach CA
« on: June 02, 2012, 12:07:23 PM »
I need to change my shocks out. What is the best way to lift the bike? I have a hydraulic floor jack but the bike needs to be stable. Also, what is the best jack point? Under engine block I assume.
« Reply #1 on: June 02, 2012, 12:22:00 PM »
best way is with a motorcycle lift
Then just pluck the shocks off one at a time..old one off new one on X2
JaysGone
Delray Beach Florida
« Reply #2 on: June 02, 2012, 02:27:01 PM »
I assuming here all you have is a regular say 2 ton car type jack??
And standard 13 inch shocks.
If so.
I just did mine this way last week for all of 10 minutes that it took.
Leave the bike on the side stand.
Remove the top bolts, both sides.
Loosen the bottoms, both sides but dont take them out!!!
Get a piece of 2x6 or a 6x6 piece of plywood.
Put the board on top of the jack under the center of the swingarm towards the engine.
Just put enough pressure on the swingarm to relieve any pressure on the shocks.
Dont lift  it more then a quarter inch and the shocks should come off, with a gentle tug without upsetting the bike.
Ignore everything I just typed if you have lowering shocks 12.5 inches or less.
The propper way would be a regular motor cycle lift as pictured.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
Mofla
San Antonio TX
« Reply #3 on: June 02, 2012, 07:12:29 PM »
Be careful not to overtighten the bottom right bolt into final drive. Mine snapped I thought rather easily ! Angry
JaysGone
« Reply #4 on: June 02, 2012, 08:43:18 PM »
Not a true technical reply on my part sorry guys.
But that sucks big time.............
      1999 Valk - SOLD
« Reply #5 on: June 03, 2012, 05:04:47 AM »
Believe me.....just about EVERY Valk I work on, the first time that bolt was so tight it was unbelievable.  That is a pin, it doesnt hold any better the tighter you make it......all it needs to be is snug like a spark plug so it wont back out on its own....same with the other bolt everyone over tightens and that is the caliper plate hold pin.........use some anti sieze on the new one and just snug it
JaysGone
« Reply #6 on: June 03, 2012, 05:19:04 AM »
I have found this bike in general harder to work on then any other bike Ive ever owned.
I dont know if its over engineered.
Or horribly engineered but a PIA in general.
I started from nothing with my rebuild, not even a manual.
Ive never needed one for a V-Twin.
      1999 Valk - SOLD
pocobubba
Pocomoke , Md
« Reply #7 on: June 03, 2012, 05:29:47 AM »
It takes patience and time to work on these bikes . I have the time but sometimes I lack the patience but we've got a great and unique bike .
« Reply #8 on: June 03, 2012, 08:02:12 AM »
Its easy when you know how to do it right........a manual, shop talk and advise from this site should ease your pain.  I find it quite easy to do most things by myself.  Or just send me your Valkyrie....Ill keep it in tip-top shape
JaysGone
« Reply #9 on: June 03, 2012, 08:17:29 AM »
As Im sure you know my back ground is 100% V-Twins and V8s.
Now regardless of what you may think about them in general.
Like anything older they are easier to work on.
A bikes a bike for the most part.
But not this one.
The Valk doesnt fit into any neat little box.
Boxer engines are a design on their own.
Uniquely different learning curve.
I have the Clymers and OEM Manual now.
I didnt when I bought this bike.
Its the small things that fustrate me Chris.
Needing compression tools to change a fork spring???
Vacuum for a petcock to work????
These things are not normal in my world.
Ill learn............
      1999 Valk - SOLD
« Reply #10 on: June 03, 2012, 08:47:15 AM »
But not this one.
Well shes a big heavy bike.  A lift sure makes tons of things easier.......As is the case for the OP in this thread, changing shocks is as easy as changing your underwear once its up on a lift.  Without trying to hyjack this thread too much:
I agree the petcock is terrible....I changed to a non-vacuum Pingel
Some have gotten good at the front forks.....I just removed mine and took them to a Honda Dealer I had a good relationship with....they changed the seals for me for $90.  Not even worth my effort if I can get it done that cheap.  Them forks are the final frontier for me, I havent learned them yet either
However, valves, air cleaner, wheels, brakes, lights, anything I needed done except the forks has been a cake walk if I used the wealth of knowledge on this site and used the Honda Book as primary guide......and the lift!
localyokel
Newport Beach CA
« Reply #11 on: June 03, 2012, 01:00:15 PM »
Yeah it's got 11 inch lowering shocks. Guess I'll need the lift.  Cry
If so.
JaysGone
« Reply #12 on: June 03, 2012, 02:45:20 PM »
Or a friend to help steady the bike.
But 1.5 inches is a heck of a strain on an already shakey side stand.
Same as every one elses and currently on sale.
http://www.harborfreight.com/1500-lb-capacity-atv-motorcycle-lift-2792.html
      1999 Valk - SOLD
SigrĂșn
Lewisville, TX
« Reply #13 on: June 03, 2012, 07:57:02 PM »
And while you're getting yourself one of those, you might want to have a peek at this item on eBay
http://www.ebay.com/itm/VALKYRIE-HONDA-LIFT-JACK-ADAPTER-DONT-BE-STRANDED-WITHOUT-IT-1-M-C-ITEM-/170789262492?pt=Motorcycles_Parts_Accessories&hash=item27c3d5549c&vxp=mtr
Had one of those for a couple of years and it sure beats the hell out of piling 2"x4" on top of each other....
IBA #54465
9Ball
« Reply #14 on: June 04, 2012, 03:50:30 AM »
It's one of the easier jobs to swap shocks...I think you'll find that it took longer to research the job than to actually do it.
With a helper you should get it done in about 10 minutes.
I did both of mine on the sidestand, one at a time, but I was replacing with same length shocks.
Good luck and be sure to report back.  Put a smear of grease on the bottom right "pin" after you clean it up real good to make it easier the next time you need to remove this bolt when removing the final drive for cleaning/lubricating.  Chris gave some great advice (above) regarding tightening.
« Last Edit: June 04, 2012, 03:53:22 AM by jrhorton » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
JaysGone
« Reply #15 on: June 04, 2012, 04:58:55 AM »
Chris I think the original gentleman has gotten more then enough info on jacks.
The Harbor Freight at $80 is a bargin and as for the stand extention easy enough to make from wood.
As to my front end.
Yes Im letting my local guy do it.
Just isnt worth my efforts.
I will just bring him the legs and let him have at it on his shop time.
By the way I do appreciate all the info you have given.
Not all here have been as helpful with some of my simple questions.
No need to reply.
Just accept my thanks.
Jay
      1999 Valk - SOLD
