February 05, 2026, 02:42:26 AM *
Author Topic: Wont pull it self  (Read 1626 times)
deadvelvet
Owensboro,KY
« on: June 03, 2012, 06:22:09 PM »
99 ins 73000 miles gears sound striped put it in gear and will move a little then just a grinding sound
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: June 03, 2012, 06:25:26 PM »
Sounds like your final drive splines just trashed. Cry
SANDMAN5
Mileage 65875
East TN
« Reply #2 on: June 03, 2012, 06:25:35 PM »
My guess would be the pinion coupling. Just a guess.
Did it happen suddenly or gradually?
« Reply #3 on: June 03, 2012, 06:36:53 PM »
Final drive is hurtin!  Undecided
My rides:
deadvelvet
Owensboro,KY
« Reply #4 on: June 03, 2012, 06:37:21 PM »
Suddenly
john
tyler texas
« Reply #5 on: June 03, 2012, 07:13:49 PM »
73000 miles ....
not so suddenly             coolsmiley
vrcc # 19002
« Reply #6 on: June 03, 2012, 07:33:45 PM »
easy fix.....Ill bet its pinion cup as well....
« Reply #7 on: June 04, 2012, 03:55:48 AM »
It sure sounds like u-joint, drive shaft splines or wheel drive splines.. Regardless, the rear wheel has to come off and you'll find it then..
Mr.BubblesVRCCDS0008
« Reply #8 on: June 04, 2012, 06:06:37 AM »
Pinion cup and driveshaft and you'll be in business. Evay to replace and fairly cheap and a 100 bucks.
Lucky Duck
Inverness, FL
« Reply #9 on: June 04, 2012, 07:41:08 AM »
I agree with the others that it's probably your driveshaft/pinion cup that are trashed. A u-joint could, but probably wouldn't, make a grinding noise. The final drive splines could be your problem but the driveshaft/pinion cup splines are usually more apt to fail.
I live near Evansville and would be glad to help if you want some help with it. 812-four eight zero- 1993.
Rio Wil
« Reply #10 on: June 04, 2012, 08:02:23 AM »
Just out of curiosity have you been doing the 10-15K miles lubrication maintenance on the rear splines and drive shaft/pinion cup?
