February 05, 2026, 04:40:55 AM *
Author Topic: I'm screwed...BUT I WIN!!!  (Read 1513 times)
biguglyman
Brockport, NY
« on: June 08, 2012, 06:42:03 AM »
Went to install my new luggage rack and despite my best efforts not to, I ended up rounding out the hex hole on one of them.  How the hell am I going to get that f#$^er out of there!?
« Last Edit: June 08, 2012, 09:41:52 AM by biguglyman » Logged
« Reply #1 on: June 08, 2012, 06:46:12 AM »
Vice-Grip.
biguglyman
Brockport, NY
« Reply #2 on: June 08, 2012, 06:54:20 AM »
Tried that.  That's how the hole got rounded out.  Not enough screw head to get a vise-grip on.  NONE of those bast%^$s want to come out!  Only got one removed successfully.  Othere ones are trying to round out too.  AAAGGGHHHHH!!!  This is why I hate working on my own crap.  Always something to make an easy ten minute job into a hair-pulling disaster. Angry
LinnB
VRCC #25552
Arnold, MO
« Reply #3 on: June 08, 2012, 07:00:05 AM »
Have you tried a torx head?  Sometimes they will grip the rounded out hole and put some WD40 on them since it sounds like they're stuck.
slider
mulberry arkansas
« Reply #4 on: June 08, 2012, 07:04:36 AM »
what worked for me--I put the correct bit in them and tapped them 3-4 times pretty sharply with a hammer and they finaly turned loose--hope this helps-good luck
a proud navy veteran
biguglyman
Brockport, NY
« Reply #5 on: June 08, 2012, 07:09:38 AM »
One of them is already rounded out real bad.  Probably going to have to drill it out and use an easy-out or something.
LAnthony
« Reply #6 on: June 08, 2012, 08:00:55 AM »
You could cut a slot in it with a dremel and use an impact driver.
« Reply #7 on: June 08, 2012, 08:25:03 AM »
If you're stuck after trying previous suggestions, buy an Alden Grabit tool set.
http://www.aldn.com/index.php
I used this tool to remove my front brake pad retention pin as described in my post:
http://www.valkyrieforum.com/bbs/index.php/topic,27923.0.html
biguglyman
Brockport, NY
« Reply #8 on: June 08, 2012, 09:45:54 AM »
As it turns out, that's exactly what I did.  Still fought me tooth and nail every step of the way and required extra drilling etc. Also had to replace the bolts.  Used some stainless ones from the hardware store until I can get some pretty chrome ones.
FINAL SCORE:    Biguglyman - 1 rack on
                       Val           - four bolts off
I WIN!
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #9 on: June 08, 2012, 09:58:53 AM »
I always did like a happy ending. (ah, I tee'd that one up. No comments from the peanut gallery!)  cooldude Grin 2funny
