February 05, 2026, 04:40:54 AM *
Author Topic: Tank emblem removal  (Read 1726 times)
giff
« on: June 08, 2012, 10:41:32 AM »
Hi Folks,
My girl got caught in a hale storm and needs a paint job Cry. How do I get the emblems off the tank without damage?
giff
greggh
OMAHA NE
« Reply #1 on: June 08, 2012, 10:51:58 AM »
WD40 and Fishing line.
« Reply #2 on: June 08, 2012, 11:00:02 AM »
Get your honey's hair dryer, and as mentioned....some fishing line. If no fishing line, some strong string will work but not as good(keeps breaking). I also suggest some gloves because it will cut into your fingers as you sorta saw back and forth with the line. I used the hair dryer off/on during the process, it's only on there with strong double sided tape and the heat softens it. I used Goof Off to clean the sticky residue off when done, then clean the surface with something less potent. Took me about a half hour for both sides.
Joe Hummer
Arnold, MO
« Reply #3 on: June 08, 2012, 11:09:51 AM »
Dental Floss works too...and it doesn't matter if it is mint or plain.  Cheesy
1999 Valkyrie Interstate
amazngrace
Eastern Shore, Virginia
« Reply #4 on: June 08, 2012, 06:26:55 PM »
For those that have removed the tank emblems, did you find a visible
difference in color due to the weathering of the exposed paint?
...ED
99 Red and Black IS
norm
« Reply #5 on: June 08, 2012, 06:34:51 PM »
waxed dental floss works the best, light heat, hair dryer no heat gun
« Reply #6 on: June 08, 2012, 10:02:37 PM »
...ED
I've removed one of those big fender emblems from an Interstate fender using the fishing line and WD-40 before.....and no, there was no difference in paint color.  Just use a pair of gloves so the line won't cut into your fingers.
ricoman
Sarasota, FL
« Reply #7 on: June 09, 2012, 05:47:33 AM »
must be some wicked strong floss, I've never seen it actually done with floss-only talked about.
Share with us the brand/type of floss.
The stuff I've tried breaks
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: June 09, 2012, 05:12:27 PM »
You can find all kinds of this stuff on the Shoptalk page...
http://www.valkyrieriders.com/shoptalk/badges.htm
Fred.
VRCCDS0237
