November 24, 2025, 11:54:50 AM *
Author Topic: Alternater mounting bolt removal  (Read 1079 times)
Whooray
Idaho State Rep
Kuna, Idaho
« on: June 09, 2012, 06:53:35 PM »
Tried to remove the alternator mounting bolts the other day and they turn just a fraction then go real tight. Im afraid to pull any harder because Im sure they will snap and I will be in a pickle. Its a 98 standard. Any ideas on getting them out without breaking them? Raymond
Vietnam Vet 6/68 - 1/70
919th Combat Engineers
11th ACR (Blackhorse)
« Reply #1 on: June 09, 2012, 06:54:40 PM »
go for a ride......try again with them warm
RP#62
Gilbert, AZ
« Reply #2 on: June 09, 2012, 09:45:10 PM »
Spray some penetrating oil on them as well and let it soak in a few days.
-RP
Tropic traveler
Silver Springs, Florida
« Reply #3 on: June 10, 2012, 12:49:48 PM »
Tap the heads of the bolts with a hammer repeatedly along with the methods the others describe.
The middle alternator bolt has been missing {broken off} for God knows how long on my '99. No ill effects at all, the top & bottom bolts are holding it just fine. Not the end of the world if the middle bolt breaks. Cool I stuck a chrome plug over the hole, I'll deal with it when I need to pull the alternator in the future.  cooldude
Steel bolt in an aluminum case can be a PITA!
'13 F6B red for Kim
« Reply #4 on: June 10, 2012, 01:31:59 PM »
Penatration oil, heat (warm bike good enough), tighten it back up, and then repeatedly loosen/tighten, to work the bolt loose.
When I didn't follow this method, I just tried harder to remove, I broke a fender rail bolt off, and had to heli coil it.
John U.
Southern Delaware
« Reply #5 on: June 10, 2012, 01:57:35 PM »
My wife's hair dryer worked for me not long ago. I also used pentrating oil and a small hammer.
Be patient, just think of all the time and effort you will save yourself if you don't break a bolt.
YoungPUP
Valparaiso, In
« Reply #6 on: June 10, 2012, 06:22:39 PM »
However you get it out use a thread chaser (NOT a tap!) before you reinstall it with LOTS of Antisieze!. I also used a vacuum cap with some grease to cover the exposed threads on the middle bolt.
99 STD (Under construction)
