November 24, 2025, 11:54:49 AM *
Author Topic: Audiovox CCS 100 servo  (Read 1572 times)
mellowyellow#7933
Verner, Ontario, Canada
« on: June 10, 2012, 06:05:48 AM »
All diagnostics done (yes, all), everything checks out. Anyone ever repair servo? Normand?
NITRO
Eau Claire, WI
« Reply #1 on: June 10, 2012, 06:33:45 AM »
You might be able to buy only the sevo from Murph's kits.
When in doubt, ride.
« Reply #2 on: June 10, 2012, 08:21:02 PM »
What is it doing...or not doing?
tank_post142
south florida
« Reply #3 on: June 10, 2012, 08:42:48 PM »
Big Mike from Valk bling and things had a lot of parts for this in a box at last inzane check with him.
I got a rock Sad
VRCCDS0246
mellowyellow#7933
« Reply #4 on: June 11, 2012, 07:55:46 AM »
No cruise engagement at all even though indicator lights on control pad function normally.
I haven't taken the servo apart yet to see if the cable may be binding
somewhere, don't know if they are serviceable or not.
alph
Eau Claire, WI.
« Reply #5 on: June 11, 2012, 04:16:49 PM »
how comfident are you with your vacuum?  how certain are you that it's there?
my cruise stopped working, the end result was a kinked vacuum line.  straighten it out, cruise works fine.
al.
Mr.BubblesVRCCDS0008
« Reply #6 on: June 12, 2012, 05:29:28 AM »
Make sure you have a good ground. If these are not grounded nothing will work. The panel will light up but that is about all. The wire (purple I think ) that wires to your brake light gets it's ground thru the brake light bulb element. If the bulb is out or not grounded the unit thinks the brakes are being used and keeps the unit from engaging. Also you can not use LED lights for the ground as this will not work. If you wire the purple wire to a good ground and unit engages then you at least know what the problem is. Be aware just do this to check unit as the unit will only disengage with the pulling of the clutch or manually turning unit off at the panel. IF you are using LEDs then you'll have to use a normally cosed relay to ground unit and use the brakelight wire to trigger the relay to drop unit off when brakes are applied.  Hope this helps.
