November 24, 2025, 05:59:54 PM
radiator FLUSHING
Topic: radiator FLUSHING (Read 1373 times)
N0tac0p
radiator FLUSHING
June 10, 2012, 09:38:35 AM »
i have read shop talk and understand replacing fluid, however is there any "flush" stuff that could be run with water (or not) to loosen and remove contaminants. then run distilled water thru to fluch then seal up, add antifreeze and water........
Re: radiator FLUSHING
June 10, 2012, 12:56:29 PM »
I would not be overly concerned about it.
Simply drain the present fluid and refill with the proper mixture.
June 10, 2012, 01:34:46 PM »
Do you have a reason to need to flush your engine, or do you just want to do it?
Coming from an area with good clean drinking water, I've never seen scale and the like in my vehicles.
N0tac0p
June 11, 2012, 02:54:17 AM »
just wnated to do it and add new 50/50 and water wetter
Mr.BubblesVRCCDS0008
June 11, 2012, 03:59:22 AM »
I usually drain and refill with water crank her up and let it idle a while drain again and refill with fresh 50/50 mix.
=> InZane XXV
