November 24, 2025, 12:07:52 PM *
Author Topic: intake o rings  (Read 1318 times)
shooter64
« on: June 12, 2012, 01:17:49 AM »
I see posts that intake o rings have to be replaced, often before 50k. What are the symptoms that appear as they get to that point?
Columbia, S.C.
mmurffy03
03 standard
toms river new jersey
« Reply #1 on: June 12, 2012, 01:54:18 AM »
ruff eneven idle you can spray starter fluid at the base of the intake runners if rpm goes higher there is air getting by the o rings beware this is also a small flame thrower you are building my bike had only 8500 miles on it and was stored in a heated garage and the orings got hard and let air seep thru at idle causing uneven idle went away with new orings
Thunderbolt
Worthington Springs FL.
« Reply #2 on: June 12, 2012, 02:53:02 AM »
visually, you will normally see some brown liquid around the joint between the head and intake.
« Reply #3 on: June 12, 2012, 05:03:55 AM »
If you need them, they are a #123 size and if you find them in viton or silicone you'll never have to replace them again. Hardware store has buna N. Not good for heat and fuel applications.
valkyriemc
NE Florida
« Reply #4 on: June 12, 2012, 04:58:24 PM »
This link may help;
http://www.valkyrieforum.com/bbs/index.php/topic,26466.msg239935/topicseen.html#msg239935
Veteran USN '70-'76
BradValk48237
Oak Park, MI
« Reply #5 on: June 12, 2012, 05:47:20 PM »
I just ordered a set from Redeye.  12.98
Brad
whitestroke
San Pedro, Ca.
« Reply #6 on: June 12, 2012, 09:48:37 PM »
I've also heard propane torch/no flame will find intake leaks.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
