November 24, 2025, 12:07:47 PM *
Author Topic: Electric Horns (non Valk)  (Read 967 times)
Mase
# 518
« on: June 14, 2012, 11:14:43 AM »
My SUV horns are sucking lately so I need to replace them.  They are a TWO wire OE set.  I found a set that I want that are a ONE wire OE set.
As long as I find the hot in the SUV's horn plug can I hook these ONE wire horns to the SUV?  It would seem simple but I do not want to blow some relays or have to add a bunch of stuff.
Any tips?
« Reply #1 on: June 14, 2012, 11:59:23 AM »
One wire horns use the horn body and the chassis where it mounts as the ground.  GM horns I've seen recently use a green wire for power, and if two wires, a black wire for ground.  If you are unsure, use hearing protection, a test light, and your favourite helper to push the horn button.
