February 05, 2026, 06:26:07 AM
carb parts
Topic: carb parts (Read 1260 times)
Poor Ol Harry
Baytown,TX. East of Houston
carb parts
June 14, 2012, 11:55:13 AM »
any aftermarket sources for carb parts?The low jets ,needle valves & bowl gaskets total $345.00,for set of 6 from Honda..... Is there a cheaper & as good source or is it what it is? Or do I just blow the jets clean & if the bowl gaskets were not leaking , use em? .....and the float valves ? Harry
Last Edit: June 14, 2012, 01:09:35 PM by Poor Ol Harry
JC
The Beast
Franklin, TN
Re: carb parts
June 14, 2012, 12:58:30 PM »
Get your gaskets from Redeye. I got slow jets for $3 each at my local dealer (aftermarket).
HDL has the needle valve for $19.68 a piece.
http://www.hdlparts.com/fiche_section_detail.asp?section=148732&category=MOTORCYCLES&make=HONDA&year=1997&fveh=3476
Shop around and you'll do much better.
Last Edit: June 14, 2012, 01:00:19 PM by JC
Poor Ol Harry
Re: carb parts
June 14, 2012, 01:15:51 PM »
Wow WEEEEE! Dealer told me like 30 some odd $ EACH! Im gonna ask him to double ck the price.& 18 for gaskets.
sugerbear
wentzville mo
Re: carb parts
June 14, 2012, 02:12:55 PM »
http://www.ebay.com/sch/redeye.tech/m.html?hash=item35b920b1a1&item=230739194273&pt=Motorcycles_Parts_Accessories&vxp=mtr&rt=nc&_trksid=p4340.l2562
Dozer
Humble, Tx
Re: carb parts
June 14, 2012, 02:24:38 PM »
Harry, I got most everything from Red Eye and HLD.. The slow jets came from HLD & were $8 ea. I measured and inspected my floats with a metric 6" scale and checked needles and seats. They looked good to me. I could shine a light through the floats and if anything had been in them I would have seen it. I soaked the carbs and parts in Gunk carb cleaner over night, rinsed them out with a water hose and blew them dry with compressed air. The slow jets looked as clean as a whistle, where I couldnt see light through them before. But again I was cautioned by folks here that they might look good but in fact may not be...so I got new ones based on the recommendations. Red Eyes carb oring kit and parts are outstanding and inexpensive compared to the dealer...and Rich is a wonderful person to deal with..and honest vendor for a change...and helpful too.
There were some recommendations that I could use the old bowl gaskets if they werent brittle or broken. They were a tad smaller it seems when I put it back together, but I used a drop or two of Scotch 1300L glue to hold the corners in place on the bowl curves. I have been busy at work so no time to work on the bike. I havent had gas in the carbs yet or got the bike to run so I dont know if the bowls will leak or not...my guess is they wont. I need to reinstall the exh pipes on the left side and replace the bowl drain hoses...then we'll see. Sure wish Rich sold ALL of the hoses...
Re: carb parts
June 14, 2012, 04:32:41 PM »
None of those item need replacing.
Clean what you can, and reuse the gaskets.
Replacing that stuff is a waste of money and there are no benefits from getting new parts.
pocobubba
Pocomoke , Md
Re: carb parts
Reply #6 on:
June 14, 2012, 06:21:39 PM »
jetsrus for all types of carb jets , hondaline for pilot screws , red eye for bowl gaskets
