February 05, 2026, 06:26:05 AM *
Author Topic: RPM drop from using the 65 size tire  (Read 1422 times)
6pak2go
Somewhere in New Mexico #30112
Hanover, Indiana
« on: June 14, 2012, 09:04:14 PM »
is apparently so and documented by lots of riders.  From all I have read, there isn't really any mention of the MPG gain and I am just curious as to what it may be.
« Reply #1 on: June 14, 2012, 09:17:39 PM »
I think this is the one I was looking for. Put in your tire sizes, and chech it out.
http://kgm.tiwing.com/calcs/tiresizecalc.htm
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: June 14, 2012, 10:02:42 PM »
I've got a 65 on my Tourer.  The rpm drop is 2-300.  That's not enough for any noticeable change in mpg.
Marty
Paxton
So Cal
« Reply #3 on: June 15, 2012, 02:40:40 AM »
With the 205/65/16 CT, my RPM @ 75 mph went down from 3500 to 3250. ???
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
JaysGone
Delray Beach Florida
« Reply #4 on: June 15, 2012, 03:35:20 AM »
I use a European light truck tire size in 195-65-16 and its for all intents is dead on the same as the stock size.
No noticable changes in any thing revs wise..
Another toy to play with to plug in tire sizes.
http://www.discounttire.com/dtcs/infoTireMath.dos
      1999 Valk - SOLD
      2005 Yamaha RoadStar
MP
North Dakota
« Reply #5 on: June 15, 2012, 04:12:56 AM »
You will see a slight increase in mpg, probably not enough to notice though.
By far, the largest component of mpg is drag. Probably 90% or more on our Valkyries.
That is why the gear change kit that used to be available did not work either.
MP
"Ridin' with Cycho"
Tropic traveler
Silver Springs, Florida
« Reply #6 on: June 15, 2012, 07:35:58 PM »
Here ya go.
205/65/16 Mich HydroEdge next to a brand new 18/70/16 Avon Cobra.
As you can see the 205/65 car tar is slightly taller. I actually thought that the 205/65 car tar was causing a higher cruise RPM but I was wrong. I bought the '99 Valk with the car tar already installed & it just sounded like it was a bit higher RPM due to the God awful sounding Cobra pipes that were on it. The Avon is on the '99 now & the difference is insignificant.
Remember too that there are variations in actual circumferences in any two same size tires especially from brand to brand.
« Last Edit: June 15, 2012, 07:38:11 PM by Tropic traveler » Logged
'13 F6B red for Kim
