April 30, 2026, 11:24:44 AM *
Author Topic: exhaust bolt question  (Read 1528 times)
doubleminded
denton texas
« on: June 15, 2012, 07:34:50 PM »
I just traded my 6 x 6 pipes to sundown for his stock interstate pipes.I had 2 choices.let the rear hanger bolts go into the hanger and not be able to mount the pipes onto the head or mount the pipes onto the head and let the hanger bolts hang down below the hanger plate.I will have to rig something to keep the weight off thepipes and head.The holes are about 1/8 to 1/4 inch off.So close.Anyhow, how tight are the 6 10 mm bolts supposed to be? My book says 180 inch pounds.My wrench doesnt go that low, but is that right? Thanks for input.
Jesus likes vakyries.
Mr.BubblesVRCCDS0008
« Reply #1 on: June 16, 2012, 05:37:30 AM »
 I was told about 7 foot pounds on header bolts and be careful as they break easy. The stock interstate pipes should bolt right up to your bike hangers. Try loosening the bolts that hold the hangers to the frame and moving the brackets some also leave the header bolts loose alittle til you get the hanger bolts started. It is a tight fit but they should work.
doubleminded
denton texas
« Reply #2 on: June 16, 2012, 07:52:20 AM »
Thanks for the tips.
Disco
Republic of Texas
« Reply #3 on: June 16, 2012, 05:42:14 PM »
I've never heard of stock pipes not fitting.  How about hanging the pipes loosely on one header bolt, loosening the hangers as much as possible, and then stabbing the pipes?
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
doubleminded
denton texas
« Reply #4 on: June 16, 2012, 08:35:19 PM »
I tried leting them hang down with barely any nut threads used, and the holes were just beyond popping into place.As it is now the pipes are mounted but the bolts are below the hangers.I will have to use a muffler strap and rig something to keep the weight off.Stock pipes are heavier than the six over six.
Sundown
NW Texas
« Reply #5 on: June 22, 2012, 03:14:03 AM »
Ron I had trouble getting those bolts in that bracket on mine.
doubleminded
denton texas
« Reply #6 on: June 22, 2012, 02:05:07 PM »
Thanks sundown.I love the quietness though.
Sundown
NW Texas
« Reply #7 on: June 23, 2012, 05:35:27 PM »
I am having to wrap the 6x6 with header wrap. First to cover the blue and heal marks, second cause of the heat.
