February 05, 2026, 06:26:06 AM
416 shocks ?
Topic: 416 shocks ? (Read 1386 times)
gregk
Retired
Chippewa Falls, wi.
416 shocks ?
June 18, 2012, 09:30:45 PM »
Thinkin about buying a set. Any new view points on these shocks? We are in the big dogs class an ride 2 up most of the time. I do have a compressor, sw. & guages from when I ran some rancho shocks years ago an then used it on som monroes after that. Is there any mods to put them shocks on a IS ?
Colin
My old job
Orba, Spain
Re: 416 shocks ?
June 18, 2012, 10:36:56 PM »
I have these on my standard and like them a lot and so does my passenger which is more important. Several people on here don't like them though. I tend to run mine rather stiffer than suggested and wouldn't go back to standard or swap for anything else.
Colin
VRCC Espana
My Bumble Bee re-build
junior
new hampshire
Re: 416 shocks ?
June 19, 2012, 01:56:17 AM »
i have the 416s and they are set at 40 psi. they give me a good all round ride and float over most potholes. they are a bolt on with no mods except the hole in the saddlebag for the valvestem. the only prob;em that i have had is the upper part of the rubber boot kept fallin off,fixed it with a zip tie
Last Edit: June 19, 2012, 01:59:01 AM by junior
gregk
Retired
Chippewa Falls, wi.
Re: 416 shocks ?
June 19, 2012, 12:01:10 PM »
junior , does that valve stem have to fit into the saddlebag because of the way its positioned or because that is the way you prefered to mount it ? I havent seen anyone post about mounting the shocks.
X Ring
VRCC #27389, VRCCDS #204
Re: 416 shocks ?
June 19, 2012, 04:11:52 PM »
I have them on my Interstate and like them. I mounted the air valve in the rear chrome tubing of the trunk mount. There is an oval port on the backside of the tubing for the antenna wires. I split a short piece vacuum line and placed it over the edge of the port and it prevents the air lines from rubbing against the chrome tubing. I drilled a hole in the middle of the tubing and stuck the air valve through. Works perfectly and looks oem.
Marty
gregk
Retired
Chippewa Falls, wi.
Re: 416 shocks ?
June 19, 2012, 07:51:19 PM »
Thanks guys. Guess I'll get some orderd after sat. night state wide poker run drawing.
Colin
My old job
Orba, Spain
Re: 416 shocks ?
Reply #6 on:
June 19, 2012, 10:27:58 PM »
I have my valve for top up mounted under the saddle. I made up a bracket for it and pop riveted it to the battery case. I keep a high pressure small racing pedal cycle pump under there too. I can do some photos if required.
Colin
VRCC Espana
Re: 416 shocks ?
Reply #7 on:
June 20, 2012, 01:47:19 AM »
http://horseapple.com/Valkyrie/Tech_Tips/A_Premium_Air_System/a_premium_air_system.html
