February 05, 2026, 06:24:06 AM *
Author Topic: blown left shock  (Read 1247 times)
CMA_Carl
« on: June 19, 2012, 07:04:17 AM »
How will the handling of the bike feel if a rear shock is blown?
« Reply #1 on: June 19, 2012, 07:14:11 AM »
I think it depends on the shock, but anytime theres a difference one side to the other it can cause unsafe instability especially at higher speeds.....be careful, get it replaced
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #2 on: June 19, 2012, 07:53:52 AM »
Unless you see leaking, double check the shock bushings...  A worn out bushing(s) can cause the bike to 'wallow' or feel like it does not want to hold a line through a sweeping curve.
If you look at the upper shock mounts, check to see that the mounting bolt is dead center in the shock eye.  In some cases, the bushing can be worn all the way through, making the bushing look like a 'C', rather than an 'o', because one side has been chewed through.
Black Dog
Don't you know...
CMA_Carl
« Reply #3 on: June 19, 2012, 08:29:25 AM »
not a bushing cause i got rid of the factory shocks about 100000 miles ago. these are the progressive shock. and yes it's covered with oil. Cry
« Reply #4 on: June 19, 2012, 10:01:31 AM »
If it is covered with oil, it has blown a seal.
Did you say it was a Progressive?
Give them a jingle and they just might fix it for free.
If they do charge ya, it is minimal.
Garland
#618
Hendersonville NC
« Reply #5 on: June 19, 2012, 10:53:15 AM »
One of my Progressive blew a seal and I rode for several weeks like that. Kind of a bouncy ride, but not particularly dangerous.
marwil
Cypress TX
« Reply #6 on: June 19, 2012, 06:13:48 PM »
mine leaked oil on brake pads made stoppin not what it used to be
