November 24, 2025, 01:52:15 PM *
Author Topic: Alternator R/R  (Read 2344 times)
« on: June 23, 2012, 10:35:26 AM »
This is for all the folks thats been talkin about how hard the alternator is to get in and out.  Its only hard if you want it to be.....do it smart and slow and it will go quick and easy.....here are some critical pictures.  Trust me theres only this way or harder ways......your choice.
First of all it pays to go for a short ride if you can to warm up the motor before trying the three mounting bolts.  (before installing put antisieze on the threads)
Next make sure the battery is disconnected!!!!!  Then make sure the battery is disconnected and either remove the battery from the bike or tie the cables away from the posts so they dont "reach" and make contact while you are working
OK, now you are ready to start.
-remove the chrome alternator cover
-remove the right and left side covers
-unbolt the center cover (both sides) or remove it altogether
-remove the three bolts holding the alternator on and with them the chrome mount for the cover
Now, as you work the alternator out (pry with a large screwdriver gently if needed you want the buggar to go straight back then angle down and toward ground beneath the center of the bike......first critical picture (like this)
Once you get the alternator to this point you can unbolt and unclip the cables.  Notice the rag under the alternator to save the paint.  Ive seen Valkyries where the paint on the subframe is chewed all up from alternator installation........Once you have it out, study the dampners, they are in pairs tied together and look so you know where the blades that drive the alternator go.
Putting it in is just the opposite.........the big mistake is NOT angling it down enough, then you get it wedged and it will be hard to get it back out and impossible to get it in............(dont ask)  Once its all lined up, get a flashlight so you can see the dampners and turn the blades until they are lined up with the openings between the dampners pairs, then just wiggle it in  (piece of cake)
Good luck Joe, and anyone else......Mine is in and putting out over 14V as it should......
« Last Edit: June 23, 2012, 11:00:17 AM by Chrisj CMA » Logged
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #1 on: June 23, 2012, 12:25:06 PM »
Thank you Chris for taking the time of publishing this post.  I've bookmarked it for future reference.
Save a horse, ride a Valkyrie
« Reply #2 on: June 23, 2012, 12:43:42 PM »
Yes thx! I have a chewed up paint on my frame.  Cheesy
« Reply #3 on: June 23, 2012, 01:34:56 PM »
Thanks Jeff.....I've bookmarked this too for future reference.
The next question is.....what's a good source for a replacement alternator?
Saw these on ebay......are these legit and is this a decent price?
http://www.ebay.com/itm/120822698205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
« Reply #4 on: June 23, 2012, 02:06:24 PM »
I lucked out and found mine on the classifieds in here.  I think MARS is the most popular source
« Reply #5 on: June 23, 2012, 02:47:21 PM »
Thanks.....just saw the post about the MARS alternators.  Bookmarked.   cooldude
http://www.valkyrieforum.com/bbs/index.php/topic,43999.0.html
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #6 on: June 24, 2012, 05:09:26 AM »
Thanks Chris  cooldude Bookmarked  Cool
pocobubba
Pocomoke , Md
« Reply #7 on: June 24, 2012, 07:28:34 AM »
Chris , what is that piece you used to mount your volt meter ? It looks great .
« Reply #8 on: June 24, 2012, 08:10:18 AM »
I made it.......just a thick old chunk of spare wood.........
FryeVRCCDS0067
Brazil, IN
« Reply #9 on: June 24, 2012, 09:31:04 AM »
This ought to be posted in Shop Talk. Well done, thanks.
« Reply #10 on: June 24, 2012, 12:24:15 PM »
I was thinking the other day about how hard it seems to get alternators
back in, and came up with: pay close attention while getting it out - that's
the way it needs to go back in...
As Jeff sez: Putting it in is just the opposite...
greggh
OMAHA NE
« Reply #11 on: June 24, 2012, 04:33:06 PM »
that's how I did mine...
real easy..
bentwrench
Philadelphia,Pa.
« Reply #12 on: June 24, 2012, 05:42:33 PM »
I keep a wide roll of that blue painters tape in my tool box.just tape of anything you might scratch and peel it off when your done.This bike is worth keepin pretty. Cool
BW
