February 05, 2026, 08:10:32 AM *
Author Topic: Spacer length for each wheel?  (Read 1693 times)
« on: June 24, 2012, 08:07:32 AM »
Honda calls them a "collar" but it's the large pipe like spacer inside each wheel that sits between the wheel bearings. On the parts breakdown used for ordering parts all I can find is a size for the front one...27x119mm, but nowhere do I find the size for the rear. I have no intention of pulling mine apart at the moment to find out, so does anyone have a source for this. Either online or you may possibly have one laying around, just remember....they're not the same size/length. So if you measure the one you have and it matches the size I mentioned above, then it's for the front wheel.
NITRO
Eau Claire, WI
« Reply #1 on: June 24, 2012, 09:00:20 AM »
The rear spacer is .885" according to X Ring's write up regarding the double row bearing mod (http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf). See page 5.
When in doubt, ride.
« Reply #2 on: June 24, 2012, 09:10:06 AM »
Wrong spacer. The one you referred to is the outer spacer, goes on the left side between the bearing and the brake caliper mount. The one I asked about is the internal one that goes between the bearings. By luck, in his write-up Marty(x-ring) shows the measurement for the spacer I'm asking about so your link did in fact give me what I was looking for.  cooldude
It shows the internal spacer as being 4.662" long, or 118.4148mm.
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #3 on: June 25, 2012, 08:54:45 AM »
John, that would make the difference about 2 hairs ??  Changed out the Radiator fluid last night and put the bike back together, rails...all good.   So I am thinkin the wheel was cut to deep?   need to up date the other thread...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
redflash
Southern New Hampshire
« Reply #4 on: June 25, 2012, 10:03:32 AM »
I have that measurement somewhere, 2.426 or somethin close. I also have a spare rear wheel spacer if ya need one, just let me know.
« Reply #5 on: June 29, 2012, 08:03:41 PM »
I happen to have one sitting in my house, but no means of measuring as accurately as you seem to already have it.
redflash
« Reply #6 on: June 30, 2012, 07:37:13 PM »
that measurement was from memory, I can measure it to the nearest 1/2 thousandth if ya like Smiley
« Reply #7 on: July 01, 2012, 09:14:45 AM »
The measurement of the spacer is meaningless without also measuring the distance between the lands and to which the spacer is to match the dimension.
X Ring
VRCC #27389, VRCCDS #204
« Reply #8 on: July 01, 2012, 10:00:48 AM »
Actually, the internal spacer or collar, if you will, takes up the space between the inner races of the left and right bearings and prevents the inner races from being pushed inward by the torquing of the axle nut.
Marty
