November 19, 2025, 06:04:10 AM
Questions about Fork Seal change.
Topic: Questions about Fork Seal change. (Read 1926 times)
Steve K (IA)
Cedar Rapids, Iowa
May 30, 2009, 06:57:47 PM »
Well, I got it torn down. Got the left tube out. The oil that came out was dirty. The upper tube is still in the triple tree. I will be refilling with BelRay 10w oil and measuring it in ounces. Will all the oil come out if I leave the lower tube standing upside down? Will that work on the right leg also? I have a tool for taking that special nut off but don't have to do that as I am not messing with the springs. So, will all the oil come out?
Thanks, Steve
States I Have Ridden In
DavRed
Buckeye AZ
Phoenix AZ
Re: Questions about Fork Seal change.
May 31, 2009, 06:24:06 AM »
As long as the tube of off the bike, and the lower piece is inserted with the seal. You can fill with the correct amount of oil. I would suggest you replace the bushings in both tubes also before you re assemble.
Steve K (IA)
Cedar Rapids, Iowa
May 31, 2009, 07:22:24 AM »
Yes, I have both sets of bushings that I will replace. Just needing to know if standing the lower tubes upside down for a while if all the oil will drain out or if I have to do any further dis assembly.
=> InZane XXV
